ecu???
Old Dec 23, 2020 | 06:32 PM
bewildered 7.3's Avatar
bewildered 7.3
ecu???
Hi friends, I finally got the new windshield installed, now I'm tackling the electrical system. The fuse/gem panel seems to be entangled with a heavy wiring harness from the steering column. I will also be replacing my park brake assembly. The ecu? not sure wth ford calls it, is in my way. I have disconnected the wiring harness in the engine bay, removed the only 2 fasteners I can find. I can wiggle it around, and the piece of the bracket that seems to hold it in place will slide aft about an inch, but it refuses to let go and come out of there. It is difficult to see if anything else is holding this to the truck. What am I missing???
Old Dec 23, 2020 | 06:40 PM
AllaboutMPG's Avatar
AllaboutMPG
If you're talking about the PCM (Power-train Control Module) then it is removed from inside the cab near the parking brake. The fastener for the electrical connector is in the engine bay and is in the middle of the connector. remove the cover inside the cab next to drivers foot to complete the removal by removing 2 screws.
Video to help
https://duckduckgo.com/?q=installing...0PGo&ia=videos
Old Dec 23, 2020 | 06:42 PM
Colorado350's Avatar
Colorado350
The PCM is held in place by a 10 mm bolt on the engine side of the firewall. The bolt backs out of the PCM but stays in the “plug”. Essentially the bolt pulls the PCM and the plug together. I recommend a 1/4” socket or a Gimbal Ratchet...you don’t want to break the bolt off! Once the bolt is free off the threaded insert in the PCM itself, you’ll have to wiggle the plug free...if the PCM has never been removed there’s 20 years of dirt holding it in place. Grab the plug not the wires... The first time I removed it I actually went in there with a small can of WD-40 and had to spray the plug to wiggle it free.
Old Dec 23, 2020 | 07:14 PM
bewildered 7.3
Video to help
Ok, Mine is mounted differently than this video, but I found another bolt hiding at the top of the bracket, now I have the PCM and the park brake out of the truck. Dark and cold out tonight, will continue tomorrow.
Old Dec 23, 2020 | 07:19 PM
AllaboutMPG
Are you in a super duty or OBS
Old Dec 23, 2020 | 07:23 PM
bewildered 7.3
Super Duty
Old Dec 23, 2020 | 07:37 PM
AllaboutMPG
Super Duty
Interesting, didn't know they mounted differently in other SD's
Old Dec 23, 2020 | 08:13 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
They don't.
Automatic transmission trucks can get by with simply removing the two 7mm-headed bolts on the plastic carrier and forcing the PCM to the passenger side and then rearward. For manual transmission trucks (where the clutch pedal assembly gets in the way), it's easier to remove the whole metal bracket by removing the 10mm-headed bolt above the park brake pedal assembly and the 10mm nut underneath the PCM bracket.
Old Dec 24, 2020 | 02:46 PM
bewildered 7.3
Originally Posted by cleatus12r
They don't.
ok, the one in the video linked above appears to have 2 mounting holes at the aft end. Mine does not have that, I have one 7mm head screw at the lower bottom, which holds a plastic sliding shuttle to the bracket. Eventually I was able to twist and pull the pcm and this shuttle away from the park brake and remove it. then I could see the 10mm head bolt above, holding the bracket in place. I needed the bracket off to remove the park brake. My 2 obstacles are the hood latch cable, in the way, and that 1.5" diameter bundle of wiring, in the way.
Old Dec 24, 2020 | 03:54 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Someone already butchered your plastic carrier. Not a bad thing, but that's not how it came from Ford.
Old Dec 24, 2020 | 05:49 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Riffraff sells the plastic case for $12 and change if you feel like replacing yours.
https://www.riffraffdiesel.com/pcm-cover-99-03/
Old Dec 24, 2020 | 07:01 PM
bewildered 7.3
ok, so #1, this rig came with a TS Performance chip in it, that didn't do anything different in any position. The guy I bought it from had the switch unplugged, said it screwed with the performance... yeah, well, maybe... I think that was the idea...lol. Anyway, the link that Paul, AllaboutMPG , posted above showed the procedure for installing a chip. I took the pcm out of the shell and there was still silicone on the terminals, so I have that cleaned up and back together. I'd like to hear some thoughts on the TS Performance chip with 6 position switch, any good? POS? anyone have or had one, liked it or not?
#2, the GEM connectors look clean, but the connectors for the fuse panel need some work. Can anyone guide me to a page for things to inspect or check on the GEM while I have it out?
#3 Have a great Christmas everyone!
Old Dec 24, 2020 | 07:07 PM
Sous's Avatar
Sous
FTE Emeritus
There is quite a bit if information pertaining to the GEM in the 7.3L PSD Tech Folder sticky thread. FTE'rs have been great contributors to the Folder and it is an incredible resource.
https://www.ford-trucks.com/forums/1...-7-3l-psd.html
Old Dec 24, 2020 | 08:58 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Just a word of caution:
Make sure you install the chip correctly and don't fiddle with it once it is installed and working. If irrepairable damage is done to that DPC-452 PCM, they are a hefty chunk of change to get a replacement unless you get real lucky.
Old Dec 24, 2020 | 11:37 PM
bewildered 7.3
Found it, great detailed information, I looked earlier, but I didn't scroll past the ads to find the goods!
