Sponsored by: Real Truck
7.3 vs 6.0
Old Dec 22, 2020 | 06:28 AM
superdaveinok's Avatar
superdaveinok
7.3 vs 6.0
Ok. I know its been beat to death but I might have a different scenario to consider.
Which would you buy ? I need a good farm truck that gets the best mpg. Don't care about bells and whistles or how it looks. Power is non issue as its only for highway and commuting. Strictly for a feed truck that can handle a lot of highway miles. Willing to modify to make it more reliable. If you had to buy and make one the most economical to drive which would it be? budget is 10-15k. 4x4 a must.
Thank you everyone.
Old Dec 22, 2020 | 08:14 AM
mikekerr's Avatar
mikekerr
Would get a farm truck for farm duties. And a Civic or Corrolla for the commute/ highway miles/ mpg and dependability. A 6.0 without a lot of investment and risk is not a commuter vehicle. And a 7.3 is pretty darn old... if maintained it is a great truck... but unless hauling a load the diesel provides no benefit.
Old Dec 22, 2020 | 08:32 AM
MountainManRobb's Avatar
MountainManRobb
If you can get a good enough deal on a 6.0 they are great. But you need to find one that has been studded correctly and not run to death with too much tune. Or one that is not and plan on dropping the coin yourself to stud the thing. Properly built and tuned the 6.0 will beat the 7.3 on mpg. Or just go with any 7.3 that is still running and they are good to go. Do you need a diesel? A gas truck might be just as good an option if you don't need to tow a lot.
Old Dec 22, 2020 | 08:49 AM
redford's Avatar
redford
FTE Leadership Emeritus
While engine to engine comparisons are good, you need to also look at other factors.
Pretty much everyone agrees that the 7.3L is a more reliable engine than the 6.0L, but the automatic transmission behind the 6.0L (5R110W) is a much better towing transmissionthan the automatic transmission behind the 7.3L (4R100).
The 2005+ trucks also have bigger brakes and coil springs on the front suspension, which equates to a sharper turning radius.
​​​​​​When it's all laid out, a 6.0L truck can usually be acquired for less money. ARP head studs, some deletions or upgraded parts under the hood can make the engine reliable, powerful and durable.
Old Dec 22, 2020 | 11:00 AM
superdaveinok
I will be up front and honest. I do not need the diesel. I just have a love for them. The wiser financial move would be to buy a midsize gas and just make due but that's not why I'm here. Really like the older trucks and for this size investment I figured I'd get something that would get the job done and be enjoyable (to me) to drive. MPG does play a factor b/c I've read some of you guys had gotten upper teens in your older 7.3 or 6.0's so that would be an added benefit. This truck will be a toy as well as a tool. I'm no diesel mechanic but can handle some light work nor do I want to go fast in any way. Just trying to find that balance between ultra reliable and good mpg.
Old Dec 22, 2020 | 12:57 PM
AK4x4's Avatar
AK4x4
If your budget is firm, and you want to keep the truck for a while, look for a 7.3 with a manual transmission that has been taken care of and is not from the rust belt. But be aware finding parts for the older trucks is an increasing challenge. If you can afford to invest more over time look at an 2005-2007 6.0 with an automatic. Again one that has been taken care of and is not from the rust belt. Then go through everything as budget permits. With good management and planning you will wind up with an really nice, mostly newish truck with 25-30K total investment. Good Luck, Russ
Old Dec 22, 2020 | 07:24 PM
00t444e's Avatar
00t444e
A 7.3 with a 6 speed manual is the obvious choice.
Old Dec 22, 2020 | 07:45 PM
Tennesseepowerstroke's Avatar
has had the
Thank you everyone.
I have owned both and my 2001 7.3 was a problem truck ie: injectors, wiring harness, and fuel injection module. I trade for a 6.0 and have way fewer problems and am still happy with it. I have don 2 turbo cleanings and the turbo was replaced under warranty also. I have done ball joints and 3 pinion. seals in 108,000 miles. It now needs 2 injectors.
Oh yes, welcome to the forum.
I think the key to success with a 6.0 was maintaining the cooling system. I started flushing and changing the coolant at 20,000 miles and still use the Ford yellow gold coolant.
I would look for a low mileage truck either way you go.
My 2001 SRW 7.3 4x4 with a 3.73 rear end got around 19 mpg on the road. The 03 dually with a 4:10 rear end will barely 16.5 mpg on the highway.
It is the luck of the draw when buying a 20 year old truck or car.
Good luck in your search.
Old Dec 24, 2020 | 06:50 AM
Arkcc522's Avatar
Arkcc522
I had an early 99 f250, 2wd, 7.3. Bought it at 92,000, gave it to my son with 407,000 miles. Always pulled 6000 lbs work trailer,. I replaced 3 sets of batteries, had ball joints replaced, transmission rebuilt at 300,000, probably 3 sets of brakes, u joints at 405,000. Best truck I ever had, I now have 2016 f250, 4wd, with 183,000 miles. Truck came from oilfield., that's ok with me. I don't know much about 6.0, heard too much wrong about them.
good luck
Old Dec 24, 2020 | 10:05 AM
Qwazert's Avatar
Qwazert
Mine was a '97 OBS with the 7.3 and E4OD transmission.
While the tranny sucked buttermilk, the truck itself was trouble-free. If well-maintained, these will approach the million-mile range.
It wasn't a strong tow-vehicle, but it was as reliable as a hammer and it never gave me any problems. I would buy another one in a heartbeat.
Old Dec 24, 2020 | 01:36 PM
Fatz29708's Avatar
Fatz29708
IMO the 6.0 is a no go, to many issues and the 7.3 is a proven winner. 6.0 trucks are readily available, 7.3's not so much, even 300k mile 7.3's are bringing a premium.
Old Dec 25, 2020 | 05:30 PM
bluovl's Avatar
bluovl
I've owned both from new, 1999 F350 7.3 4x4 CC Dually, and a 2005 F350 6.0 4x4 CC Dually. Traded the 1999 on the 2005, big mistake. While the 6.0 was like a hot rod it quickly developed problems. Got rid of it while it was still under warranty. The 99 was the best truck I ever had. Currently have a 2002 CC F550 no problems. I'm the second owner 150,000 miles on her. Just wish it was 4x4.
Revolution
Apr 23, 2006 06:59 PM
Justforfishing
Nov 27, 2005 09:00 PM
GubNi
Mar 21, 2005 03:03 PM
Tonecapone7777
Mar 23, 2004 12:21 AM
carbonboy2000
Feb 21, 2004 09:28 AM
