Sponsored by: Real Truck
Parasitic Battery Drain?
Old Dec 21, 2020 | 01:03 PM
ralphie123's Avatar
ralphie123
2005 F350 Lariat, 6.0 diesel, experiencing battery drain. Not using it much but not enough juice left after one week to use the door keypad. Batteries are only two months old. There's nothing plugged into the 12v outlets or anything installed. Help, I don't even know where to start.
Old Dec 21, 2020 | 07:48 PM
Bugzilla46310's Avatar
Bugzilla46310
Did you have the drain prior to swapping the batteries?
Old Dec 22, 2020 | 08:37 AM
ralphie123's Avatar
ralphie123
I think so, but I thought the three-year old batteries were failing and replaced them without having the alternator checked. I'm charging up the batteries and will do an alternator check this morning.
Old Dec 22, 2020 | 09:19 AM
jetty's Avatar
jetty
With your multi-meter in ammeter mode, check the DC ampere draw on the batteries with the truck parked.
Old Dec 22, 2020 | 10:45 AM
RV_Tech's Avatar
RV_Tech
However. before reading the amp draw shut it off and let it sit so everything shuts down for about 30 minutes, then check the draw.
Steve
Old Dec 23, 2020 | 09:35 AM
super 6.8's Avatar
super 6.8
While checking the draw at the battery, start popping fuses out until you eliminate the draw. Now you will know what circuit is the culprit.
Estam
Jan 18, 2017 04:32 PM
HillbillyJoe
Sep 13, 2016 12:51 AM
dezridin2
17
Apr 29, 2012 06:37 PM
Rancheroracer
2004 - 2008 F150
Feb 4, 2009 04:06 PM
Railmonkey
2004 - 2008 F150
15
Mar 13, 2006 10:18 AM
