2006 f350 6.0l battery drain
Old 09-12-2016, 10:32 AM
HillbillyJoe's Avatar
HillbillyJoe
HillbillyJoe is offline
I have a small battery drain and when I check. It with a multi meter on 200ma it reads 04.0 is this too much of a drain, when I pull fuse #3 (upfitter#3) it drops to 02.0
Old 09-12-2016, 01:54 PM
diesel_dan's Avatar
diesel_dan
diesel_dan is offline
So that is 4 milliamps? how are you checking it, disconnecting one battery and putting your meter in-line off the other? Do you have anything hooked in to up fitter #3?
4 milliamps actually doesn't seem that high to me...
Old 09-12-2016, 01:55 PM
WatsonR's Avatar
WatsonR
WatsonR is offline
As in 4 milli amps..
That would basically be nothing, would be .04 if the decimal were in the right place.
Old 09-12-2016, 02:51 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Sure it's not 40 mA? Remember 1000 milliamps = 1 ampere.
Old 09-12-2016, 03:10 PM
diesel_dan's Avatar
diesel_dan
I usually use an auto-ranging meter, but I have others: he said he put it on the 200 milli-amp range, so that is 0 - 200 milli-amps or up to 2 tenths of an amp at that range setting; so 4 would be 4 thousandths of an amp... as Randy says: nothing...
Old 09-12-2016, 04:29 PM
HillbillyJoe
Yes I unhook one battery completely and test from the negative post on the other battery and yes the meter is on 200ma...but my batteries keep going dead after a day or two not running...the meter reads 04.0 on 200ma...I just have the plain Jane model f350 with no accessories but cruise and a.c. but when I pull fuse #3 (upfitter #3 according to manual) the drain drops to 02.0 on 200ma
Old 09-12-2016, 05:16 PM
WatsonR's Avatar
WatsonR
WatsonR is offline
after you turn the truck off, sit inside for a bit, about 30 seconds. That should allow the time out timer to activate, try the window down button. If it goes down, its the cluster timer.
Sure your checking it in D/C and not A/C? Even 200 milliamps isn't really anything of a load.
Old 09-12-2016, 06:46 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Right, even 40 mA is excellent. 4 mA is just noise..
Old 09-12-2016, 07:51 PM
HillbillyJoe
I have manual windows...that is why I am so confused, no accessories to stick on just a.c. and cruise are the only amenities and yes I am positive I am checking on dc camps.
Old 09-12-2016, 08:00 PM
wedge542's Avatar
wedge542
wedge542 is offline
Do you have anything plugged into the obd plug? Any trailer hooked to truck?
Old 09-12-2016, 08:07 PM
HillbillyJoe
No trailer and nothing in obd plug and nothing in power point...could it be a dead ground
Old 09-12-2016, 08:16 PM
wedge542's Avatar
wedge542
wedge542 is offline
Have you tested both batts seperatly? Any coroding on post? Any acc wires besides factory hooked to batts like aftermarket alarms and such?
Old 09-12-2016, 08:21 PM
WatsonR's Avatar
WatsonR
WatsonR is offline
Sun visor lighted mirror, under hood light?
With your tester, negative probe to a good ground, check every fuse in the box under the steering wheel to see if something is pulling power. Make sure the ground is not the box itself, but something like the body or a pedal mounting bolt.
The drains happening when batteries are connected, not with ground disconnected and 4milliamps ain't it.
Old 09-13-2016, 12:51 AM
da-bees's Avatar
da-bees
da-bees is offline
Pull both neg cables off and see if battreies dis-charge. Bad battreies will dis-charge without any draw on them. Before reconnecting cables,ck voltage on each battery.
12.6=full chg
12.2=half chg
12.0=25% chg
kidoo
01-31-2014 07:37 PM
vjsimone
6.4L Power Stroke Diesel
06-16-2013 01:41 PM
dezridin2
17
04-29-2012 06:37 PM
Mike in Ohio
02-29-2012 06:50 PM
Rancheroracer
2004 - 2008 F150
02-04-2009 04:06 PM
Quick Reply: 2006 f350 6.0l battery drain
