Sponsored by: Real Truck
Relay Needed for Heated Mirrors?
Old Dec 23, 2020 | 08:41 AM
SoCalAngler's Avatar
SoCalAngler
Added a power tow mirrors with blinkers and heat to my 2003. This was about 1-2 years ago. Never hooked up heat as it really isn't needed much where I live.
Now I want to hook up heat to a push button lighted switch. The switch is rated at 10amps.
Is a relay needed between the switch and mirrors or can wires from mirrors be connected directly to switch? There is one wire from each mirror.
NOTE: My OEM tow mirrors only came with power (no heat or turn signals).....I wired in turn signals myself.
Thanks!
Old Dec 23, 2020 | 10:21 AM
projectSHO89's Avatar
projectSHO89
Can you determine the current draw for each heater?
The factory version uses a 20A fuse in the circuit so a relay is likely a very good precautions. A 10A switch may not be sufficient.
Old Dec 23, 2020 | 10:33 AM
SoCalAngler
Since heat was not on my trucks OEM to mirrors originally, would there be an existing fuse location for heated mirrors? If so, would it be supported by a relay?
Old Dec 23, 2020 | 10:41 AM
projectSHO89
Check for a fuse, or at least contacts, in CJB location F09 under the dash.
m.gil
2009 - 2014 F150
Dec 20, 2019 08:16 AM
Gianni
Aug 17, 2017 02:00 PM
homade
Nov 11, 2011 08:20 AM
shpaint1
Oct 14, 2009 12:35 AM
savage250
Sep 18, 2007 04:01 PM
