Battery drain
Old Feb 3, 2009 | 04:28 PM
Rancheroracer's Avatar
Rancheroracer
Battery drain
What's normal for battery drain, ('08 F-150 5.4 auto). My battery goes dead if it sits for a couple weeks, I checked & it has .3 amps drain.
Old Feb 3, 2009 | 05:56 PM
Buck 1's Avatar
Buck 1
No way it should drain to the point it is dead after sitting for a couple of weeks unless you have an accessory that is on constantly. Think about it, if that was the case every vehicle on the dealers' lot that had not been started in 2 weeks would have a dead battery. Time to go back to the dealer and get a new battery.
Old Feb 3, 2009 | 06:50 PM
Flying_Dutchman's Avatar
Flying_Dutchman
Could be the Alarm/immobilizer. My car used to drain dead after a few days if the alarm was left on.
Old Feb 4, 2009 | 03:43 PM
wdbates's Avatar
wdbates
300MA is to much.. If you are checking Amps at rest the MA reading should drop after a few minuets to 50-75ma tops
Old Feb 4, 2009 | 04:06 PM
Rancheroracer
Yes, it starts out at over an amp, (lights flash), then drops to .30 amps. I need to do some more checking. Battery dropped overnight to 12.32 from 12.49.
Jontx
2009 - 2014 F150
13
Oct 25, 2021 09:03 AM
minnesota-clint
Apr 8, 2014 03:08 PM
noel431
2004 - 2008 F150
Apr 18, 2010 02:35 PM
Zccornett
Electrical Systems/Wiring
Feb 21, 2003 12:00 PM
wolfmanagh
1997 - 2003 F150
May 8, 2002 04:38 PM
