Battery Drain
Old Apr 10, 2012 | 10:02 AM
dezridin2's Avatar
dezridin2
Battery Drain
I have a 1984 F-350. Something is drawing from the battery while sitting. Could it be the clock? Any ideas?
Old Apr 10, 2012 | 11:02 AM
81ChopTop's Avatar
81ChopTop
The clock will always pull power, along with a newer digital radio if so equipped, but not that much.
A way to track it down is pull a battery cable (either one) and put a test light in between the cable and battery terminal. (If the light is real bright, there's a major drain. If it's real dim, it shouldn't be a worry). Start pulling fuses until the test light goes out or shows really dim. Once you find out what circuit the drain is on, you can track it from there.
Are you experiencing a dead or low battery after sitting?
Old Apr 10, 2012 | 12:02 PM
Grubbworm's Avatar
Grubbworm
Old Apr 10, 2012 | 01:11 PM
82f100460's Avatar
82f100460
Yeah some get pretty worried about the memory in the newer stereo's and the analog clocks. Gotta think of it this way. If you have a battery operated clock...you put a couple AA batteries in it and it goes for 2 or 3 years. It's gonna take a long time to drain a car battery
Old Apr 10, 2012 | 02:34 PM
1986F150six's Avatar
1986F150six
Sometimes systems are incorrectly installed...
This is true, BUT sometimes stereo systems are incorrectly installed even by specialty shops... my son had a very nice system installed along with an amplifier. If he did not drive everyday or two [tough when you are in the ARMY], the battery would go down. The way the amplifier was wired, it remained energized all the time, even though the unit radio/stereo unit was off.
Old Apr 10, 2012 | 03:01 PM
82f100460's Avatar
82f100460
good point...hard to compensate when somebody, you pay, installs things incorrectly
Old Apr 10, 2012 | 03:02 PM
dezridin2's Avatar
dezridin2
I have a new motorcraft batt in it. I did the light test,and it checked out ok. Ford wont give me a new battery because it the third one. Will do the fuse test next. I just thought someone had the same problem.
Old Apr 10, 2012 | 03:06 PM
82f100460's Avatar
82f100460
Not sure what you mean by the light test checked out ok? Are you saying you disconnected one of the battery leads and put a light in and it did not come on?
The light test and fuse test are to be done at the same time. You connect the light...if it shines brightly then you have a drain. Leave the light connected and pull fuses until the light goes out. When it does....you then know what fuse circuit your drain is on.
If you did the light test and there is NO drain....then you have no drain.
Old Apr 10, 2012 | 03:14 PM
dezridin2's Avatar
dezridin2
The light was real dim. So I must have a drain then. Thanks
Old Apr 10, 2012 | 03:34 PM
81ChopTop's Avatar
81ChopTop
What I would do next is isolate where the power is going. It'll take a bit of time, but it will give you definite results. Pull off the center panel (two screws) and unplug the clock and radio. By doing this, it takes them completely out of the equation.
Then do the light test by the battery again. If it still lights, yes, there's a drain and it's time to pull fuses and check circuits.
If it doesn't, then you have other problems. Time to check connections and grounds.
Have you had the alternator tested in the vehicle?
Old Apr 10, 2012 | 03:45 PM
dezridin2's Avatar
dezridin2
I have not had the alternator checked. It shows its charging.
Old Apr 10, 2012 | 07:28 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The rectifier diodes are like a one way valve.
The alternator can be charging while the engine is running and sucking power with the engine off and key out.
Old Apr 10, 2012 | 07:36 PM
dezridin2's Avatar
dezridin2
Ok...I did the amp meter test like it says above, It came up I was draining @ 40 mill amps. So I disconnected the stereo and it looks like that is what was draining the battery..yeah!
thanks a lot to all of you...
Old Apr 10, 2012 | 08:13 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
4/100's of an Amp is not likely to kill your battery unless you're talking about it "sitting" for months at a time.
Old Apr 10, 2012 | 08:23 PM
82f100460's Avatar
82f100460
yeah 40 miliamps is nothing...that's just the clock/memory.
If you're battery is going dead and this is all the load on the battery...then I'd say you have to have a battery issue.
