timing issues
Old Dec 19, 2020 | 11:58 PM
mustang81's Avatar
mustang81
timing issues
i rebuild my 400 with aussie heads and tim piston for the aussies heads.i also install a retro fit kit from crane cam to accept 460 roller rocker. when i install the double row timing set with the -4°, 0°,+4°. i set it up straight a 0°. my question is did the timing mark are still good on the harmonic balancer? from the factory my 1979 400 had a retard 4° timing chain set up.
Old Dec 20, 2020 | 04:22 AM
lizardman1's Avatar
lizardman1
Yes, the same
Old Jan 3, 2021 | 08:30 PM
tbear853's Avatar
tbear853
Timing marks on the balancer refer to piston position like top dead center. Have nothing to do with cam timing.
Old Jan 4, 2021 | 09:35 AM
beartracks's Avatar
beartracks
The outter ring of the balancer can slip over time. You would need to find top dead center and compare it to the marks to be sure.
Old Jan 5, 2021 | 06:46 AM
Tedster9's Avatar
Tedster9
The camshaft phasing will not change the TDC indication on the balancer no matter where it is installed - straight up, advanced, etc. Don't worry about that. However, it would be wise to employ a degree wheel or, some other method of positively verifying that the camshaft is truly where you want it, in terms of valve timing.
Old Jan 16, 2021 | 08:19 PM
Tedster9's Avatar
Tedster9
@mustang81 Any luck?
Scolesy8
Mar 23, 2008 08:30 PM
Scolesy
Mar 10, 2008 04:48 PM
tex02
Oct 14, 2006 05:54 AM
78fordranger
Jul 16, 2006 09:14 AM
78f250_rls
Jul 3, 2005 11:58 AM
