1998 Navigator. Changed thermostat because engine wasn’t warming up and heater not warming up. Now car is heating up ok but heater both front and back not heating up. Any ideas?
Reason: More info
Wait - if the water pump were bad, wouldn't the engine be overheating??
I'm having a similar issue in that I have NO heat whatsoever, although the engine heats up to temperature just fine. I used to get a small amount of heat *if* I kept the blower on "lo". Now, nothing. I had assumed that the blend door had finally stuck all the way shut.
The heater hoses get hot; I have never attempted to measure a temperature difference between the two, but I assumed that if I wasn't getting airflow across the core (blend door stuck in the 'cold' position) I wouldn't see a temperature drop. Is that a bad assumption?
More likely in the summer than the winter. But that aside, the water pump by design pushes more coolant through the engine than the heater system, which is why when the coolant is low the heat will blow cold even though the engine isn't overheating.
Totally agree with respect to *coolant level*....but the OP said "a bad water pump". In any season here in the "lower 48" I would expect an engine to overheat if the water pump failed.
True, but a bad water pump is not necessarily a failed water pump. I've seen water pumps with damaged impellers that still pumps coolant, just not as much as they should.
