1978 - 1996 Big Bronco
Heater Probs
Old Oct 11, 2002 | 01:30 PM
Black_Bronco's Avatar
Black_Bronco
Heater Probs
I have a 93 and I am having heater problems no or very little heat even after i drive for any period of time. any suggestions where to go first?
Old Oct 11, 2002 | 01:43 PM
alanscott's Avatar
alanscott
Heater Probs
First thing I'd do is make sure the engine is warming up, a thermostat stuck open will make for a cold heater. If the engine is warm, check the heater hoses to make sure both sides are hot and there are no restrictions in the water flow. Try these and get back to us, we'll go from there.
Old Oct 11, 2002 | 05:56 PM
JBronco's Avatar
JBronco
Heater Probs
There are two thermostats available for Broncos. A 160 and a 180, I believe. When I moved to Colorado I could not get any heat in the winter until I switched to the hotter t-stat. Solved the problem.
Old Oct 11, 2002 | 06:37 PM
Kaptain20's Avatar
Kaptain20
Heater Probs
