heat???
Old Apr 27, 2007 | 11:29 AM
ncfirefighter46's Avatar
ncfirefighter46
heat???
okay i have a 93 ford explorer and with the heat off i get heat out the vents, and it on cold. and i dont have that great of heat in the winter and i got anti freeze smell inside what can this be?
Old Apr 27, 2007 | 12:06 PM
Backin72's Avatar
Backin72
Anti-freeze smell inside the truck pretty much means your heater core is leaking. Fairly easy to replace and an inexpensive fix.
If you take a look at the firewall, passenger side, you will see two hoses going into the truck. On those two hoses is a valve which regulates whether you get anti-freeze flowing into the heater core or not. Since it sounds like you will be replacing the heater core, you might as well replace that valve at the same time. That should cure the heat all the time in your truck.
You should also replace the thermostat at the same time. That should fix your lack of heat in the winter. Replace with a 195 - 197 degree thermostat. Make sure you get a gasket with it as sometimes the new thermostat doesn't come with one.
Good luck.
Fandini
Electrical Systems/Wiring
Dec 28, 2011 09:50 PM
homade
Nov 11, 2011 08:20 AM
miner999r
Feb 14, 2009 11:07 PM
bigoguide
Jan 14, 2008 03:51 PM
cyberboss
Aerostar
Nov 23, 2003 12:59 PM
