03 randomly dies
Old Dec 17, 2020 | 09:42 AM
Lockholder's Avatar
Lockholder
03 randomly dies
So we got the batteries replaced because they were bad. But when the girlfriend went to drive it home it randomly shut off on her and wouldn’t start in P or N. I replaced the CPS about a month ago and a few months prior to that. So this morning I went to see if it’ll crank and if it didn’t I’d check the ICP but it turned over and fired right up. Are these two things a good spot to be checking for the issue?
Old Dec 17, 2020 | 09:50 AM
Lockholder's Avatar
Lockholder
While it started this morning I pulled the icp the idle changed and then I plugged it back in a few seconds or minutes later and it died and it’s back to a crank no start
Old Dec 17, 2020 | 12:03 PM
Walleye Hunter's Avatar
Walleye Hunter
How's your IPR? Is the tinnerman nut on tight? Check connections and chafing where the harness rubs on the VC on the driver's side?
Old Dec 17, 2020 | 02:36 PM
Lockholder's Avatar
Lockholder
Ipr nut is tight no chafing
Old Dec 17, 2020 | 02:50 PM
HKusp's Avatar
HKusp
Where'd you get the CPS? Is it an International or Ford?
Old Dec 17, 2020 | 02:53 PM
Lockholder's Avatar
Lockholder
ford CPS been having to change then around here and there
Old Dec 17, 2020 | 02:55 PM
HKusp's Avatar
HKusp
So do you have the ability to log data? Do you have the Torque App or AE or anything like that?
Old Dec 17, 2020 | 02:56 PM
HKusp's Avatar
HKusp
When you say, it won't start in P or N, do you mean it won't crank and fire or it won't even crank?
Old Dec 18, 2020 | 12:05 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Well hey, test results. ICP prolly has oil on top, check it out. Clean harness with brake clean and replace ICP, genuine Ford or IH strongly recommended over much cheaper imports.
You can run the truck with ICP disconnected. Won't run great, but it will go and cause no harm.
Old Dec 18, 2020 | 01:28 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
David has some good advice for you and I wanted to help make your decision on sourcing an ICP easier for you if you decide to move forward with that.
Clay at Riffraff Diesel - https://www.riffraffdiesel.com/injec...-sensor-97-03/
Bob at Diesel-O-Rings - https://www.dieselorings.com/14-022-...z-9f838-a.html
Some dealers (Ford/International) will price match if you are in a hurry, but as David said, the 7.3L will run just fine with the ICP unplugged until the new part comes in. Both Clay and Bob are active on the FTE and are site sponsors. Do not purchase a POS labeled as an ICP...
Old Dec 19, 2020 | 02:13 PM
Lockholder's Avatar
Lockholder
sorry for late replies. Icp and CPS are all ford. I checked icp and didn’t see oil on top as if it was bad. Thinking of changing both and seeing what happens
Old Dec 19, 2020 | 10:06 PM
aawlberninf350
It's a Van Gogh
For less money you can get Torque app and a BT dongle as Jason suggested, then you can see how the ICP is working. Plus clear codes etc.
Old Dec 20, 2020 | 08:08 AM
Sous's Avatar
Sous
FTE Emeritus
If I may add to what David has suggested, but change the application of choice.
FORScan is much more user friendly and helpful when troubleshooting. TorquePro is good to look at and works 100% of the time 60% of the time, but FORScan is rock solid and will do everything you need it to.
Check out the following links if you wish to go that route:
Popular scan tools are the BAFX or OBDLink devices. These are not the only choices, but anything that is capable of reading J1850 PWM should work. There are limitations to some of the applications and scan tools based on using Android, iOS or Windows as well.
Old Dec 20, 2020 | 08:11 PM
aawlberninf350
It's a Van Gogh
Thank you Sous, good call. I was thinking Forscan but I typed TP, lol!
Old Dec 24, 2020 | 05:13 AM
Jamon Norton's Avatar
Jamon Norton
My truck was randomly dying and not wanting to restart. I changed cpa and tried unplugging icp, no fix. But then I wiggled the engine wiring harness and it died. Long story short the wires were rubbing on my frx and a valve cover bolt and shorting. I cut some heater hose in half put it over the wires and fixed. So maybe check the wiring harness that runs over top of your engine
