6.0l no start help!
Old Dec 11, 2020 | 08:10 PM
Nick Meighen's Avatar
Nick Meighen
6.0l no start help!
So I have an 06 f-350 and I recently replaced the hpop because I was driving and had little to no power out of nowhere and then the truck died and I was told the pump went out. Replaced the pump and the truck fired right up and after a little while started sounding back to normal. The next day went to start it and would just crank and not start and showed a code for the crankshaft position sensor. I tried unplugging the icp and starting it but that didn’t work. Now after a few days of fiddling with it it still doesn’t start but has a code for the icp sensor circuit fault and has now started blowing a lot of white smoke when cranking but still won’t start. Any advice is appreciated.
Old Dec 11, 2020 | 10:25 PM
LindenBruce's Avatar
LindenBruce
Who replaced the HPOP? How was it determined to be the fault? Can you post the DTC's you had/have right now? B.
Old Dec 11, 2020 | 10:29 PM
Nick Meighen
I swapped the hpop myself and I know a guy who Owns a shop and he put his computer on the truck and checked it over and beloved that the pump gave out and the codes are p2285 and p2617 however the icp code may have come about by me cranking on it with the icp unplugged but I’m not entirely sure
Old Dec 12, 2020 | 05:55 AM
Visurveyor's Avatar
Visurveyor
You need a reader to post some more info. Such as
icp psi
Icp volts
Ipr duty cycle%
Rpm,s while cranking
cam and crank SYNC
Those are a few to look at. There's a good chance you had a little gunk get in your system wile working and it went to you ipr screen. Might want to look at that. Did you replace crank senser and pigtail?
Old Dec 12, 2020 | 03:30 PM
Nick Meighen
icp psi
Icp volts
Ipr duty cycle%
cam and crank SYNC
no I did not change the sensor and pigtail but I changed the screen to a new one on the pit when I swapped it and can you recommend a scanner that can see those without costing a ton of money?
Old Dec 12, 2020 | 04:04 PM
LindenBruce
I have the OBDLINK LX and it gives me much of what I need. But thinking of getting the MX as it offers more data and features. B.
https://www.totalcardiagnostics.com/...-2019-reviews/
Old Dec 12, 2020 | 04:42 PM
bismic's Avatar
bismic
ForScan Lite download is apprx $5.
The BAFX adapter is about $25.
Old Dec 12, 2020 | 09:02 PM
Visurveyor's Avatar
Visurveyor
Forscan Lite and +1 on the adapter.
Old Dec 12, 2020 | 10:27 PM
Nick Meighen
icp psi
Icp volts
Ipr duty cycle%
cam and crank SYNC
I got a scanner that reads more stuff the icp was at 1500 the icp voltage said zero but I got 5 volts at the plug with a multimeter the Roma were around 500-1000 and ipr was at 68 and sync was 1
File Type: mov
Old Dec 13, 2020 | 07:49 PM
Nick Meighen
icp psi
Icp volts
Ipr duty cycle%
cam and crank SYNC
ok I replaced the IPR so that’s down to 40 right now but it seems like the fuel bowl up on the engine is only half full and isn’t filling more and everything is just cranking is the something I should check in my field delivery to help remedy that?
drinkerofstone
Oct 18, 2019 12:51 PM
9357
Sep 25, 2019 06:59 AM
rmgraw351
Nov 15, 2015 06:49 PM
neoxaero
Feb 16, 2014 08:29 PM
Ford from above
Jun 1, 2004 07:43 PM
