Sponsored by: Real Truck
Crank but no start with p0672 code
Old Sep 24, 2019 | 08:06 PM
9357's Avatar
9357
Truck recently would not start indicated camshaft position sensor replaced now reads p0672 cranks but will not start
Old Sep 25, 2019 | 06:59 AM
Djosbun's Avatar
Djosbun
Who told you it needed a camshaft position sensor? If you had a DTC pertaining to the camshaft position it is usually the camshaft phasers that is bad, as it is no longer able to move the camshaft and leaves the cam stuck in an advanced timing state. Also, you must use Ford camshaft phasers as the aftermarket units are garbage.
However: your current code is for a glow plug problem.
-- Dave
Savspanky
Oct 10, 2025 10:28 PM
fordf350man
22
Nov 23, 2016 03:46 PM
BobsF350
May 6, 2012 09:10 AM
grady24
Nov 11, 2009 07:19 PM
