Upfitter Switch Access
Old Nov 29, 2020 | 08:31 AM
mbopp0153's Avatar
mbopp0153
I'd like to install a dash cam in my 2019 F-250. Since it doesn't draw much power I want to tie directly into a upfitter switch in the overhead console. This will give me a few inches of wire run instead of having to hide the wire coming from under the dash.
So, does anybody know how to remove the cover to get to the back side of the upfitter witches?
Old Dec 28, 2020 | 02:36 PM
Fatz29708's Avatar
Fatz29708
DC is probably 5v and that will require a converter.
The upfitter switches will pull out and they are held in place with tension clips, if they are oem, the wiring will not be at the back of the switches, it will be down at the e brake area, you will see a bunch of short as hell wires they expect the normal human to be able to attach to, good luck with that, look in the owners manual and it will give some straight forward instructions.
Old Dec 28, 2020 | 05:45 PM
Franklin2's Avatar
Franklin2
I looked at a 2018 model. It does send 12v to the upfitter switch itself, but it's only on a 5 amp fuse and runs several of the switches.
mojavearcher
Jan 13, 2021 02:39 PM
Tmarshallg
Jul 28, 2017 04:04 PM
Greynomad
Nov 16, 2015 03:06 PM
jimbo beam
Aug 10, 2007 04:34 PM
Boyle067
Jul 20, 2004 04:20 PM
