LED Light bulbs for Instrument Panel
I’ve conducted a search for type and number of bulbs in my dash and found one video on YouTube with a guy who has an F-350. Very helpful video, but I am unsure if the bulbs (number of/type) is exactly the same as my 2000 Ex.
Anybody know the answer as to what type and quantity of LED bulbs are needed to make the change?
Thanks.
Thanks.
https://www.ford-trucks.com/forums/1...cks-build.html
Post #5, it's on my to-do list as well...
there's also a post in the tech folder for other component LED swap;
https://www.ford-trucks.com/forums/1...l#post14855531
Be prepared, the area on the speedometer around the 50-70 mph range won't be as bright as the rest giving a "dimmer" look. I've not heard of anyone who found the reason or fix for this. Nature of the beast I guess. If someone does have the answer/fix for this, please let us know. You will see a huge improvement of brightness in your instruments and it's a welcome improvement. Be sure to get high quality dimmable bulbs. Not a job you want to do multiple times.
I have had really good luck dealing with Super Bright LEDs, so far, with my rear brake lights/turn signals and flasher relay. The site said to use the same color light bulb as what you are trying to illuminate and it worked great for my Ex’s rear end, but they don’t make any color or brightness recommendation concerning the gauges. They give three (3) different brightness levels and then a separate selection for color. I sent them a question about this. Hopefully, they will be able to help.
Oh, by the way, changing out the flasher relay was definitely a pain. I ground down the edges of the trash bag hook opening and still wound up with this:
If I can figure out how to make a YouTube video, I’ll post up what my brake lights do when I hit the stop pedal.
For ANY led bulb, I use VLEDS. Especially for brake and backup lights. Go as bright as you can and let those behind see what you're doing!
https://www.vleds.com/shop-applicati...ghts/3157.html
https://www.vleds.com/shop-applicati...ngle-bulb.html
I even added the license plate light so I can really see when I back up!
I posted pictures of the brake lights activated and the back-up lights activated on another thread. Here's the link: https://www.ford-trucks.com/forums/1...xorcist-2.html
I did a lot to this truck in 2020, and 2021 promises a lot more. Fortunately from here on out is mostly cosmetic.
For all of the below mentioned bulbs, I only recommend the 5000K color. Anything higher looks too blue
VLEDS 194 style bulb - 14-LED
VLEDS 74-style bulb
For your cluster illumination you'll want 5 of the 194 style, and one of the 74.
I don't recommend swapping the indicators, except maybe the blinkers. It's not worth the money or headache. At the end of the day, it's your call and your truck. If you decide you want to anyway, order the color that corresponds to the color it appears on your dash. It will look much more vibrant than white bulbs. My ever-fading memory wants to say it's 7 Red, 6 Amber, 3 Green, and 1 Blue.
VLEDS T5
If you want to do your HVAC controls, grab two more 74. I highly recommend you do this while doing the cluster illumination. It's SO easy to get to them while your dash is apart.
If you want to do the overhead HVAC, they take a pair of 194 bulbs, but it's pretty bright...too bright. The standard halogen bulbs do a better job there.
My build thread will answer most of your questions in posts #5-9, & #18
Good luck!
VLEDS 74-style bulb
VLEDS T5
Good luck!
