2003 Excursion bumpers and Black Friday
Old Nov 25, 2020 | 08:28 AM
thor363's Avatar
thor363
Guys, looking through the following for my Ex., winch ready and more protective than the stock stuff is all I'm really looking for. Occasionally pulling people out of ditches around here, and using for other stuff around our properties also.
Iron Cross
Hammerhead
Smitty built
....and a few others. I wasn't wanting to pick up bumpers yet due to Cummins conversion stuff I'm working on, but....40% off is a bit hard to pass up. Bypassing painted bumpers, and prefer black powder coated.
Most of the front bumpers I can sort out just fine, but the rear fitment is the bigger question, having seen gaps and strange fits from various brands.
Any good recommendations based on real life experience. Not sure whether for the front I want to protect the full front clip or just raised bull bar.
Thanks!
Old Nov 25, 2020 | 02:39 PM
DieselTekk's Avatar
DieselTekk
Trailering
If you know how to weld check out Move Bumpers. Cool way to save a few bucks and looks to be pretty good stuff.
Old Nov 26, 2020 | 08:34 AM
DinoB's Avatar
DinoB
https://www.bumperonly.com/products/...f350-superduty. Check out the Fusion bumpers. They list them for SD not for Ex but IMO they look pretty clean.
Old Nov 26, 2020 | 12:55 PM
Dan V's Avatar
Dan V
I got a Move kit last Black Friday....you had better know how to fit/miter/cope round tubes in to angled flat surface, and be a fairly competent welder.
My kit was on the order of $700. Then I spent the better part of a week (part timing it) fitting on the truck and fitting the brush guard portion. Plan on spending some time with a grinder and in my case, a 4" belt sander. Oh, now that the thing is welded up, you have to choose what you are going to do for a coating. (rattle can, bed liner, powdercoat, etc.)
I went with powdercoat, and I had them match the Raptor grille color.....but they need to sandblast prior to powdercoat....so after they do that....you hand them a check for $550.
Old Nov 27, 2020 | 09:23 AM
SmackDaddy's Avatar
SmackDaddy
$1250 all said and done? You can get a Ranch Hand for less than that. Yours looks very nice though. Excellent work!
Old Nov 27, 2020 | 03:04 PM
EXSwap's Avatar
EXSwap
I don't generally like the full brush guards, but that looks pretty darn nice!
Old Nov 27, 2020 | 10:02 PM
thor363's Avatar
thor363
Move is not even a consideration on my short list.
Old Nov 28, 2020 | 10:20 AM
Tminus5's Avatar
Tminus5
RH cheaper?
Uhh, send a link to where you see a Ranch Hand complete bumper replacement for under $1250 and I'd buy it in a heart beat.
Old Nov 28, 2020 | 10:02 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
here is one pretty close to that, use discount code RANCH50 for $50 off and has free shipping.
Also look for a little button on the site down around the bottom left that only appears every few visits that also offers you $25 bucks off for signing up for their newsletter/alerts.
https://bumpersuperstore.com/i-11556...1997-2003.html
This is where i have gotten bumpers for several vehicles.
Old Nov 28, 2020 | 11:19 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
considering picking this guy up for my Excursion, the rear bumper leaves something to be desired for durability and looks compared to my ranch hand front bumper...
https://bumpersuperstore.com/i-23908...2000-2005.html
Old Nov 29, 2020 | 06:24 AM
ASFC27FTFBQ's Avatar
ASFC27FTFBQ
Here is a pic of my Aluminess rear bumper:
This is with the swing arms closed. I’ve got two (2) boxes (one for each swing arm) to hold a seven (7) gallon cylinder fuel tank and Honda generator.
This is with the swing arms open. Each arm is rated at 150 lbs. The tolerance between the Ex’s frame and mounting plates of the bumper is so close, the bumper actually scraped the undercoating off the truck when installing it. Can you say “tight.”
Welds are very uniform. Couldn’t be happier.
For the front, I’m saving my pennies for a Buckstop Outback. It has a aluminum option, for weight reduction, and designed for a Warn 16.5 winch. I plan on mounting a pair of Rigid spots in the two (2) light holes.
Good luck with your selection.
Old Nov 30, 2020 | 04:07 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
Bumper superstore promo code for cyber monday dropped, free shipping and 5% off total order, which for most bumpers means $100+ off
CYBER5
Old Nov 30, 2020 | 05:02 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
Just pulled the trigger on the hammerhead excursion bumper that has tow shackles and flush mount lights with the discount code.
Old Nov 30, 2020 | 05:03 PM
spartan's Avatar
spartan
The Aluminess rear bumper post is quite amusing. Cracks me up. Everything about it including the reflections.
Odyssey350kc
Nov 23, 2017 09:45 AM
Agg2001
Aug 18, 2013 08:37 AM
Skip1970
Mar 31, 2010 02:40 PM
fordlover99
Mar 6, 2005 05:15 PM
GordoPanocho
2004 - 2008 F150
May 21, 2004 11:52 AM
