3" to 2" hitch reducer for 2020 F-350?
#31
#32
My F-350 SRW with 7.3 came with the 2.5-in and no sleeve. I happen to be back at the dealership and mentioned it to my salesman. He went and grabbed one off of another truck in the lot. Fast forward two months and I go to use it with my bike rack, only to find out he pulled a 3-in to 2.5-in reducer which obviously does not fit in my receiver. I'm seeing some of them on the lot have the sleeve, some do not. I think it's just random luck. If you have a nice salesman, they'll probably grab one for you.
Meanwhile, I'm still in the market for a 2.5 to 2-in sleeve and have to get rid of my oversized one.
#33
The following users liked this post:
#34
#36
#37
#38
I can’t answer your question directly, but this one is pretty nice. The price is right. And because of the way it’s made, it works with my Thule bike rack.
https://www.easternmarine.com/buyers...adapter-rta302
#39
#40
I know my 2017 came with reducers but I'm not sure if it goes all the way down to 2". I primarily use the fifth wheel hitch.
This should fit your truck though: https://www.etrailer.com/p-38735.html
#41
I am going down this rabbit hole too. My rack uses a custom pin that is too short for a 3'' receiver. This etrailer one specifically says:
Note: This Reese Super Titan reducer sleeve does not work on Ford OEM 3" hitches.
What does that mean?
#42
Received 6,976 Likes
on
The only thing I can figure out is that it is specific to the Reese receiver, which must somehow be different than the Ford receiver. Beats me though. A 3" receiver should be a 3" receiver.
#43
my 2020 250 with a 3" receiver only came with the 3"-2.5" adapter. I found a 3"-2" solid 1 piece adapter made by Husky Towing, 33129, but there were none in stock without a planned in stock date.
found here:
https://www.rvupgradestore.com/Husky...hoCSxkQAvD_BwE
I ended up buying a CURT 3-2.5 / 2.5-2 adapter set and welded them together to give me a solid 3-2 adapter. So, now I have the factory 3-2.5, and a 3-2.
found here:
