All I have ever seen are two part, 2 > 2.5 > 3. They are all metal on metal so that will rattle.
Originally Posted by JayCarver
I don't mind spending extra for a good product.
If you are willing to spend a bit, I'd recommend just getting a good 3 inch shank, 6 inch drop hitch, with changeable ball sizes. It will run you a few hundred dollars, but you wont have to mess with lining up reducer sleeves, rattle will be minimal, and you will be able to make the most of the 3 inch hitch.
I never use anything 2.5" so if its available a 3" to 2" would make more sense.
Do any of them have anti rattle provisions?
Thanks!
I used a 2.5” to 2” reducer for a while on my ‘19 F250. I pull a trailer everyday, the rattle and slop in the hitch was ridiculous. The amount of wear from the slop has caused the hitch pin hole to wallow out and I swear I can grab the ball and the whole hitch moves up and down a few inches. Tossed that and went with a Weighsafe 180 hitch, 2.5” shank 6” drop. $229 on ebay shipped. No slop and much less noise. Now my work trailer doesn’t sound like it will snap off the hitch on every bump.
This is what I did. 4 of my trailers are 2 5/16 ball, 1 is 2 inch. So for my F 250 I bought a 2.5 inch shank Shocker Hitch with the 2 appropriate ball sizes. Adjustable drop. Pricey? Yup. But one trailer is used pretty much every day from late March until late October and another gets pulled about 3,000 miles round trip full of motorcycles on vacation every year so it was worth it to me.
Shocker is also available for 3 inch receivers.
https://shockerhitch.com/
I would also avoid any adapter that will push extend the length of the draw bar.
The farther the trailer hitch is from the axle, the more tendency to sway, so short is best. I have even had extra holes drilled in the draw bar to get it up nice and tight to the truck.
Example: I would avoid this: https://www.etrailer.com/Hitch-Adapt...ese/38735.html
I also recommend getting the matching size shank. I towed with the 2" shank and it was noisy even with the WDH at full configuration. The hole for the pin in the receiver wallowed out a bit from using the reducers. Once I went to the 3" shank that stopped.
+3 on just buying a new 3" shank.
I only have one trailer and its 2 5/16 so I just bought a new 3" hitch and 2 5/16 ball.
I did not want to mess around with any adapters.
Go to a welding shop and have them put a sleeve on your 2" to bring it to 3" and weld in place. I have a 2-1/2 inch and use the correct shank, but when a friend bought a new truck it had the 3", I sleeved his shanks to 3" and with the sleeve welded in place on the shank he has almost no rattle and he is not wallowing out the pin hole.
I highly recommend this setup, I bought the same hitch, with the matching locking pin. If you're worried about the hitch rattle, by the Hitch Clamp brand anti rattle clamp. This is a very secure quality setup.
My preference is to use a 3in shank. But when I have to use a 2.5 or a 2in... I've been very happy with the Curt reducer set. Much better than the OE sleeve.
