Drag Link Length Issues
Old May 19, 2022 | 12:53 PM
duckduke's Avatar
duckduke
Originally Posted by ray86
Where would the stabilizer go?
Or do you not run one with that drag link?
I realize this is an old thread but it's good info and this question was never answered.
On the PMF drag link, you can use a clamp (stabilizer clamp) like the ones linked in the post above you. You would mount the clamp in roughly the same position on the PMF drag link where the hole is for the bolt on the stock drag link.
But, many installing this drag link simply add and use a dual stearing stabilizer set up. The original stearing stabilizer is removed/deleted.
Then, there are those that use both. The orignal mounted using the added clamp, and, the dual stabilizer.
Dual stabilizers set ups can be obtained from PMF. Carli, ICON, Superlift, and probably a few others.
Hope this helps!!!!!!
Old May 20, 2022 | 08:12 AM
speakerfritz's Avatar
speakerfritz
The OEM steering device is a steering damper ....prevents bump steer.
Old Jun 19, 2022 | 10:15 AM
deveroutdoors's Avatar
deveroutdoors
Does anyone have the proper part number from Moog for the standard drag link (not wide track)?
DS300037, DS300040, and DS300041 are all incorrect.
I see the MevoTech MS40764 mentioned here but no online parts stores have it within a reasonable amount of time.
Ford part number stamped on the drag link is P622D.
Why is it so hard to find a drag link for a current model truck?
Old Jun 20, 2022 | 12:38 PM
deveroutdoors
If anyone needs this, here is the correct OEM part number for 2017+ narrow track drag link:
HC3Z-3304-A
Stamped on the rod is P622D. Printed on the box along with the part number is MDF13. It appears Ford has 3 different identifiers for the same product.
raven_zilla
May 23, 2021 09:37 AM
Rmack941
Sep 13, 2020 11:20 AM
GoinBoarding
May 8, 2018 02:06 PM
OldFords4Life
Aug 8, 2017 10:05 PM
glennemay
Jun 15, 2010 02:02 PM
