Sponsored by: Real Truck
Stabilizer Link
Old Jun 15, 2010 | 06:47 AM
glennemay's Avatar
glennemay
Stabilizer Link
OK, So PartsguyEd came through with flying colors. Sent my Stabilizer links at lightning speed.
Here's the catch. I went to install the right side one and realized that I need to either move the Y Pipe, or the engine?
Just looking for some suggestions..
Thanks
Glenn
Old Jun 15, 2010 | 09:31 AM
glennemay's Avatar
glennemay
Wow? Are we playing stump the experts?
Maybe a little more information on the truck may help.
2004
F350 DRW XL
V10 6.8
4x4
Long bed
Just hoping someone has some hints for replacing the vertical links (Dogbones) on the stabilizer without dropping my exhaust or jacking my engine. I am unfortunately limited on resources for lifts, etc on this vehicle.
Glenn
Old Jun 15, 2010 | 02:02 PM
glennemay's Avatar
glennemay
Success!!!!!!
Well, THAT was not nearly as bad as I thought it was going to be.
The stabilizer link is attached to the frame via a block that is bolted to the bottom of the C channel. Once I got this off, I could pop the link right out of there and replace.
If anyone else has this issue, keep in mind that you CANNOT just buy one link. Ford has re-designed them to the point where if you replace only one you will rip the other one out in the process shortly after the installation.
Just thought I would toss that one out there for ya!
G
pkthomas
Crossovers
Apr 23, 2014 09:15 PM
emmagator
Feb 25, 2008 08:16 PM
epos48
Feb 27, 2006 07:21 PM
hink10
Jan 1, 2006 11:13 AM
