Post market wireless CarPlay
Old Jun 18, 2022 | 09:20 AM
iConnect's Avatar
iConnect
Smile Post market wireless CarPlay
Besides the annoying fact of having to connect/disconnect every time you go in and out of the truck, the problem of the wired CarPlay is that every time you connect your phone you are also charging it, which you might not need and long term can also reduce the lifespan of the battery. So I was using it but not that often…
While traveling for work I rented a couple of cars with wireless CarPlay, and I found out I really liked it, all the advantages and none of the cons. So I got myself a “CarlinKit 3.0” that transforms the wired into wireless. It’s a simple little box that you connect to the USB port, and after pairing once it’s automatically connecting every time you go in. I have been using for the past week or so and it works very well, no problems whatsoever. I really like it, navigation with Google Maps in Terrain mode is absolutely gorgeous!
With the promotion by Amazon it costed $80, a pretty good deal:
Amazon Amazon
Old Jun 18, 2022 | 05:17 PM
B-737's Avatar
B-737
Is there a delay while this is connecting / loading? does it need to connect to carlin wireless network? if so, how does the transition work from your home network to the carlin kit wifi?
if you do need to charge your phone, I guess you need to use the charging port on dash or in the console, because if you connect it to the sync port, its prob going to get confused. Or maybe that could be done with a cable that blocks data...
Old Jun 19, 2022 | 02:58 AM
GABAR's Avatar
GABAR
Having an iPhone plugged into the USB port constantly for using CarPlay or not, which means it’ll be fully charged, does not affect the lifespan of its battery.
Glad to hear that your wireless CarPlay adapter is working well for you but be prepared for faster iPhone battery drain.
Old Jun 19, 2022 | 11:24 AM
iConnect's Avatar
iConnect
There’s a little delay when you get into the truck, some ten seconds or so, and then the bluetooth connection goes on automatically. No other connection necessary, so no messing with wifi.
I already added a wireless charging pad to the center armrest, if I need to recharge I simply put the phone on that. So everything is now wireless…
Old Jun 19, 2022 | 11:29 AM
iConnect's Avatar
iConnect
I keep reading a lot of different takes on that matter, I cant find a definitive answer about keeping the battery under charge continuously… So for the moment I try to keep batteries between 20% and 80%, which seems to be the safest advice. If I use the battery for CarPlay no problems…
Any case when I am in town I use the truck for relatively short trips, and it was really annoying plugging/unplugging for say a ten minutes grocery trip. And therefore I was only using it for longer trips. With the automatic wireless it’s now always on…
Old Jun 20, 2022 | 09:36 AM
mewaschuk's Avatar
mewaschuk
i did a similar wireless dongle. i also added this non slip qii charging pad. fits perfectly on the floor cup holder tray of the 20% section.
charging pad charging pad
Old Jun 20, 2022 | 09:54 AM
slowmans's Avatar
slowmans
I had purchased the same one, I noticed that for whatever reason the phone wont connect to the trucks hotspot though? I returned it for that reason, I am assuming that the bluetooth connection was causing the Iphone to not connect to the hotspot?
Old Jun 20, 2022 | 10:17 AM
iConnect's Avatar
iConnect
I don’t use the truck’s hotspot, so I don’t know if it would make a difference… Mine is connecting flawlessly every time…
Old Jun 20, 2022 | 03:49 PM
Mike_in_STL's Avatar
Mike_in_STL
The charging circuitry and algorithm on all modern phones does not permit the battery to be charged when the battery is full. Lithium Polymer batteries don't suffer from memory either. Whether you have Android or Apple, the internal charging circuit monitors the capacity of the battery and shunts the power from the USB when the battery doesn't need it. It's a safety feature as lithium is very unstable and doesn't take well to over or under voltage, the former causing thermal runaway and fires. It's one of the reasons we now have chargers that can fast charge a battery using a higher current. So plug your phone in with a quality cable and don't worry that your battery life is being diminished.
cmk1's Avatar
cmk1
Wireless car play uses wifi connection to the box/head unit, so you cannot connect to 2 wireless systems at the same time.
RV_Tech
All Things Towing
21
Apr 29, 2016 07:35 AM
Bird-Dog 250
16
Mar 1, 2016 08:21 PM
ReAX
Electrical Systems/Wiring
Dec 7, 2008 12:57 PM
SolidGround
Mar 20, 2007 01:32 AM
rmilchman
Mar 9, 2004 09:15 AM
