6.7 Engine replacement parts
Old Nov 11, 2020 | 01:31 AM
davidrr9398's Avatar
davidrr9398
OWNER, I have to replace the engine in my 2012 F-250 Lariat Crew Cab I have ordered a ford "fully Dressed" reman engine. I will be replacing the idler pulleys and tensioner serpentine belt upper and lower hoses and front transmission seal. Anything else that is worthwhile replacing while the engine is being replaced?
Old Nov 11, 2020 | 06:41 AM
The Bone's Avatar
The Bone
May as well replace the any part that is difficult to remove after the engine is installed. Alternator, water pump, power steering pump. Depends on how many miles you have on your truck. But since you have access to all this stuff it's a no brainer.I forgot the turbo. The 12 has a problem with the bearings. a good upgrade is a 15 unit. there is a kit to make that work.
Old Nov 11, 2020 | 07:19 AM
senix's Avatar
senix
So, a long block or a crate motor?
Old Nov 11, 2020 | 11:19 PM
davidrr9398
Owner
The engine will be a Ford complete motor with turbo, injectors, injector pump. Ford refers to the engine as a "Fully Dressed" plug and play engine. The truck it is going into has less than110,000 miles.
davidrr9398
6.7L Power Stroke Diesel
Nov 11, 2020 03:34 PM
LonnieD
Aug 6, 2013 02:15 PM
billj6
1983 - 2012 Ranger & B-Series
Feb 26, 2012 12:01 PM
jtwest
Nov 19, 2003 01:52 PM
