If I put my climate control on 60, it blows cool air almost a slight bit warm
I I put it on any other setting for a/c it blows as cold as it should.
seems to me like its confused and thinks 60 is 75.
I was never overly impressed with the climate controls on these trucks. Say you have it set at 70. And the outside temp gets within 5 degrees of of that it turns on the ac full blast so you have to crank it up to 75. Then when it gets above that you have to turn it down to 65 so it does not turn on the heater.
I don’t even use dual climate control all it does counter act each side.
