6.7 Engine replacement parts
Old Nov 11, 2020 | 01:30 AM
davidrr9398's Avatar
davidrr9398
OWNER, I have to replace the engine in my 2012 F-250V Lariat Crew Cab I have ordered a ford "fully Dressed" reman engine. I will be replacing the idler pulleys and tensioner serpentine belt upper and lower hoses and front transmission seal. Anything else that is worthwhile replacing while the engine is being replaced?
Old Nov 11, 2020 | 11:55 AM
davidrr9398
The truck has 109,000 miles on it and the replacement engine will be a complete ford engine with injectors, injector pump, turbo ford calls the engine a "plug and play" fully dressed engine
Old Nov 11, 2020 | 03:34 PM
speakerfritz's Avatar
speakerfritz
Before dropping that motor I. I would try to do a causation root analisys of why the motor failed and see if any associated systems need to be replaced.
davidrr9398
6.7L Power Stroke Diesel
Nov 11, 2020 11:19 PM
LonnieD
Aug 6, 2013 02:15 PM
billj6
1983 - 2012 Ranger & B-Series
Feb 26, 2012 12:01 PM
jtwest
Nov 19, 2003 01:52 PM
laptopgeek
May 7, 2002 08:12 AM
