C6 - Running On Engine Stand
Old Nov 2, 2020 | 08:03 PM
54TexasF100's Avatar
54TexasF100
Hello Friends,
I want to run an engine and transmission (C6-1989) on an engine stand. I have the torque converter connector (w/ 1 quart Type F). Do I need to connect the trans cooler lines? How many quarts do I need to add to the trans to be safe (it was empty)? Any other precautions I should follow?
Thanks,
Stephen
Old Nov 2, 2020 | 08:31 PM
ford390gashog's Avatar
ford390gashog
Loop the cooler lines together. Add 4 more quarts to the trans. Crank the engine and check again, you should be able to add 4 more. You will want to make sure the trans has proper fluid level before you try running the engine or you risk pump damage. Type F isn't the correct fluid for a C6 after 1977 unless you want really hard firm shifts.
Old Nov 5, 2020 | 09:51 AM
alloro's Avatar
alloro
Don't forget to run a hose into the water jackets to keep the engine from overheating.
Old Nov 13, 2020 | 11:48 AM
baddad457's Avatar
baddad457
Originally Posted by 54TexasF100
Hello Friends,
Thanks,
Stephen
You need the driveshaft yoke in the rear too.
rustywheel68
May 24, 2011 12:31 AM
daddy57
Jan 27, 2008 08:24 AM
Saigon
Sep 16, 2006 07:01 AM
ford390gashog
Nov 17, 2004 07:39 PM
Craig
May 24, 2001 04:39 PM
