C6, how many quarts
Old Sep 14, 2006 | 12:19 PM
Saigon's Avatar
Saigon
C6, how many quarts
Hi,
Just got the trans and transfer case on after changing the trans pump,I just had 4 liters ( 4.5 quarts) trans fluid handy, truck won't go into gear.How many mimnimum quarts should I put in before it engages. I took off one of the trans cooler lines and it does spurt eracticaly, not a steady flow!
Thanks
Old Sep 14, 2006 | 04:13 PM
tjc transport's Avatar
tjc transport
i ain't rite
according to the shop manual, a dry C6 trans and torque converter install should require about 12.5 liters of trans fluid.
Old Sep 14, 2006 | 04:55 PM
Saigon's Avatar
Saigon
Wow! I didn't have the figures..... I guess 4 liters is no way near enough, just enough for the converter I guess,will have to do some shopping tomorrow!
Thanks
Old Sep 14, 2006 | 06:53 PM
DNewton's Avatar
DNewton
would that be the same for a 2WD truck with a c6.....please convert that into quarts please...lol and is there a specific type i need to put in for diesel trannys?
Old Sep 14, 2006 | 07:10 PM
tjc transport
i ain't rite
well a liter is about the same as a quart, so if it is a dry trans and dry torque converter, start with 10 quarts and add till full. 12.5 liters should relate to about 13 quarts. 2 wheel or 4 wheel, it makes no difference, the transfer case is seperate from the trans. the only thing they have in comon is they both use dextron/mercon fluid.
my 88 c6 took 14 quarts with the extra trans cooler. i also used valvoline max life synthetic, as per the recomendation of the trans rebuilder.
Old Sep 14, 2006 | 08:04 PM
fellro86's Avatar
fellro86
1L=1.057 qts, so close to 1:1. Sounds like you got that pump working now, just gotta keep enough fluid on it...
Old Sep 15, 2006 | 01:07 AM
Saigon's Avatar
Saigon
Thumbs up
Yea!What an ordeal!Will get some atf today and top up.At least one good thing is that after sitting for a month the 7.3 fired right up after two tries, runs nice and smooth.
Old Sep 15, 2006 | 12:05 PM
Saigon's Avatar
Saigon
Talking
Got everything running,filled up the trans and did a few forward/reverse tries, was a bit shy at first,engaged late in both drive and reverse,rechecked the fluid and was about a liter low.Will try it out on the road tomorrow and see if it runs up all three gears.
Old Sep 15, 2006 | 02:11 PM
tjc transport
i ain't rite
ain't it nice when a plan comes together??
Old Sep 16, 2006 | 07:01 AM
Saigon's Avatar
Saigon
Yea, very self-rewarding! I cleaned the engine,trans and transfer case with a pressure washer, let it dry and started her up,took it for a test drive and it seems to be OK, I just have one small leak at the oil pan gasket but I can live with that for now, too tired to dismantle again.Thanks for your advices, really helped me out!
bcaughhorn
Nov 17, 2016 04:37 AM
kyle j
Sep 4, 2011 09:37 PM
Impacttec1
1997 - 2003 F150
Jul 31, 2006 12:25 PM
Steve95
1978 - 1996 Big Bronco
Mar 14, 2006 07:57 PM
xspeedyx
1997 - 2003 F150
Nov 21, 2005 09:12 AM
