Starter is free spinning
Old Nov 1, 2020 | 09:40 AM
LiveFrom1977f150's Avatar
LiveFrom1977f150
At first starter didnt always disengage after starting, it would hiss until i nudged the key back to start once or twice with the engine already started... After about 6 months of it doing that intermittently it turned into a situation where i have to turn the key 5 or 6 times before the starter will engage with the flywheel. The starter just free spins. I assume the solenoid isn’t moving the starter to engage. Is their an easy fix for this or is a new starter the real fix i should be doing?
Old Nov 1, 2020 | 09:45 AM
smle's Avatar
smle
Sounds like that's in the starter itself. The bendix isn't kicking out to engage.
Old Nov 1, 2020 | 09:54 AM
HoustonDave's Avatar
HoustonDave
Think of a starter as having a couple of main parts - the motor part and the bendix gear (as I recall) which is the gear at the end of the starter shaft which actually engages the flywheel ring gear. The starter has to spin, and that gear has to engage, for the engine to turn over. Usually people have problems with the starter motor not spinning due to rust, crud buildup, worn brushes, lack of battery juice, etc. because the gear end of it is pretty bulletproof. Gear, shaft, a spring... what could go wrong? But it has. Sounds like for some reason the gear is not engaging with the flywheel ring gear, so the starter spins free with no resistance. I would drop the starter and check that that gear slides on the starter shaft. Haven't looked at a Ford starter, but on the ones I have seen you can try to work lube under that gear to get it to slide more easily on the shaft. If that works, you're in good shape. If not, well, you're already half-way through the replacement.
Old Nov 1, 2020 | 10:10 AM
ford390gashog's Avatar
ford390gashog
A replacement starter would have been 6 months ago. The bendix is stuck and you're just going to cause ring gear damage.
Old Nov 1, 2020 | 11:10 AM
LiveFrom1977f150
Sounds like ill be replacing the starter in the coming weekends. Appreciate the responses.
Old Mar 15, 2025 | 02:36 PM
Dmb07atx's Avatar
Dmb07atx
1st Gear
Im having same issue!
I know its not the starter. When I jump it at the solenoid it works perfect
Old Mar 15, 2025 | 09:39 PM
Rubiranch's Avatar
Rubiranch
I went thru 2 rebuilds within just a few months.
I bought a new starter from rockauto.com for $100 and haven't had a problem since.
Old Mar 15, 2025 | 11:59 PM
tbear853's Avatar
tbear853
What?
Thread says ""starter is free spinning" but if it works jumping the solenoid, it ain't so free spinning.
Old Mar 16, 2025 | 10:39 AM
AK FORD GUY's Avatar
AK FORD GUY
Originally Posted by tbear853
What?
Old thread and Dmb07atx was not the OP.
Old Mar 16, 2025 | 12:39 PM
tbear853's Avatar
tbear853
Dmb07atx said he had same issue just yesterday post 6? Original poster had a longer post, more detail, & clearly had a messed up starter drive.
Oh well ...........
Old Mar 16, 2025 | 12:47 PM
beartracks's Avatar
beartracks
If? it work fine when shorting the solenoid it would point to low voltage or an ignition switch problem.
Old Mar 16, 2025 | 04:36 PM
AK FORD GUY
Oh well ...........
I missed that part tbear. Hopefully he gets it figured out.
Old Mar 16, 2025 | 10:06 PM
Rubiranch's Avatar
Rubiranch
thread started back on Nov 1, 2020
adamkat22
51
Sep 4, 2015 07:53 AM
Kendrick
Apr 9, 2011 08:58 PM
seizure911
Feb 17, 2008 10:54 PM
Unimog005
Jan 29, 2005 09:37 AM
Frank Lang
Apr 4, 2004 08:55 PM
