Starter issue
Old Apr 9, 2011 | 04:40 PM
Kendrick's Avatar
Kendrick
Starter issue
I just had my starter tested the other day and put it back in. you can hear it turning when the key is turned but its like the teeth never engage the engine.
any one have suggestions on it?
Old Apr 9, 2011 | 05:07 PM
Fordownsall's Avatar
Fordownsall
starter solenoid? they tend to go bad more than the actual starter itself.
Old Apr 9, 2011 | 06:47 PM
Kendrick's Avatar
Kendrick
thats what i was wondering to. any suggestions on how to test?
Old Apr 9, 2011 | 08:06 PM
farmert's Avatar
farmert
It might be the gear on the end of the starter.
Old Apr 9, 2011 | 08:12 PM
BlueOvalBud's Avatar
BlueOvalBud
Maybe there's a spot on the flywheel with some missing teeth?
Pull the FSS wire off the IP and turn the engine over by hand with a wrench to see if it will turn the flywheel enough to grab an area with good teeth.
Just a thought
Old Apr 9, 2011 | 08:58 PM
84-6.9L's Avatar
84-6.9L
Ya, a guy i know that does trans work told me a motor always stops in the same spot just about everytime. So you could have a bad spot in the ring gear. It could just be the bendix, you should just be ablr to get a drive for it they are alot cheaper then a new starter and easy to put in. if you take the starter back out make sure the drive gear only turns one way on the drive.
ThrashinDad
Aug 23, 2013 05:35 PM
DDPJ
15
Nov 16, 2012 09:16 PM
98XLTBeast
Oct 6, 2005 08:42 AM
BroncJMU
1978 - 1996 Big Bronco
Dec 21, 2004 08:20 PM
patmorrison
13
Feb 27, 2004 03:20 PM
