SYNC 3 PROBLEM
Old Oct 31, 2020 | 11:12 AM
k5rcd's Avatar
k5rcd
Trailering
SYNC 3 PROBLEM
2018 super crew XLT 4wd 5.0 v8 18k miles.
Sync 3 ver. 3.0 build 18093, sync serial # VXA000F2
I've had no problem since new, but now when playing tracks from Soundcloud, it will stop in the middle of a track, and my android (Galaxy S10E) screen says "Not playable track cannot be streamed". I'm using Bluetooth as I've never been able to play Soundcloud through Android Auto as it doesn't recognize it, All was well until recently. I have done a reset on Sync 3 (held in FF> and radio power switch at the same time, and also rebooted my android phone). When away from the vehicle or truck is turned off, the phone plays the tracks as normal, so the issue isn't with the phone itself, or with Soundcloud. Phone is right next to the radio. Amazon Music does the same thing but with different error message something like "error, try again later".
HELP Mr. Wizard !
Thanks.
Old Oct 31, 2020 | 12:34 PM
SpencerPJ's Avatar
SpencerPJ
Does it work correctly when phone is plugged in with the cord to the truck? Did you delete the Bluetooth connection from your phone and re-establish it?
Old Oct 31, 2020 | 02:29 PM
k5rcd's Avatar
k5rcd
Trailering
When phone is plugged in I can only stream Amazon Music, but it works OK on that. I did delete the phone and re - paired it and uninstalled and reinstalled Soundcloud to no avail. Just tried it with my wife"s Galaxy S10e and it works fine. I guess the problem must be in my phone. I will take it to the repair shop Monday. Thanks for the reply.
Old Oct 31, 2020 | 06:56 PM
GABAR's Avatar
GABAR
Get an iPhone and your problems will be solved.
Old Nov 1, 2020 | 09:01 AM
k5rcd's Avatar
k5rcd
Trailering
Thanks so much for that helpful reply..
GROW UP !
Old Nov 1, 2020 | 11:26 AM
GABAR's Avatar
GABAR
GROW UP !
You’re quite welcome.
Have a good day.
fire3110
May 3, 2017 08:46 AM
Hercsmomma
Feb 20, 2015 03:32 PM
Demo-man
6.7L Power Stroke Diesel
Jan 14, 2014 08:58 AM
Tom282
Jan 11, 2014 11:48 PM
