6.7 fuel system failure CP4 disaster prevention kit design flaw.
Old 05-23-2024, 02:59 PM
UGA33's Avatar
UGA33
UGA33 is online now
DCR’s seem to be holding up well.
The following users liked this post:
  #167
Old 05-23-2024, 06:19 PM
Overkill2's Avatar
Overkill2
Overkill2 is online now
Received 6,766 Likes on 4,927 Posts
Wow... 2800 miles a week... INSANE.
I'd also add that the videos S&S did on one of the DCR testing trucks that had been getting bad fuel, water laden, and DCR chewed up the fuel and spit it out with no issues.
  #168
Old 05-24-2024, 11:05 AM
WXboy's Avatar
WXboy
WXboy is offline
Yes it's true the DCR did keep operating normally after that water contamination. But, the bearing faces did get scored pretty heavily. He showed that up close in part 2 of the video. I wonder if that would *eventually* lead to problems? Particularly if it happened again.
  #169
Old 05-24-2024, 12:54 PM
Overkill2's Avatar
Overkill2
Don't remember that part but I was amazed that after pulling the DCR and checking it out, they put it back in the truck.
I'm sure if you kept feeding the DCR crap fuel, it would go but I remember them saying there would be no catastrophic event of metal debris going through the fuel system like what happens with the CP4 when one fails...
  #170
Old 05-27-2024, 08:58 AM
senix's Avatar
senix
senix is offline
Received 1,555 Likes on 1,109 Posts
I think that if I have water in the fuel, depending on the amount I would pull and inspect then decide.
  #171
Old 05-27-2024, 09:16 AM
Overkill2's Avatar
Overkill2
When do you have plans to get the DCR installed Scott? You doing it or are you having a shop do it?
  #172
Old 05-27-2024, 09:22 AM
senix's Avatar
senix
senix is offline
I am having my sister's shop do it. Should be ready tomorrow.
I could have done it myself but due to the "lower" or family rate it is just hit the easy button. The pump alone is worth it at <1K.
They guy has done several so far and of the techs has it in his F450.
The following 2 users liked this post by senix:
  #173
Old 05-27-2024, 09:35 AM
Overkill2's Avatar
Overkill2
That's AWESOME you have the know how to do it... I don't know if I'd be so inclined to install the DCR and I don't have another vehicle to drive... Post up here once it's in and what you think... Good stuff.
BVA
6.7L Power Stroke Diesel
02-21-2019 08:23 PM
hansenlink
05-18-2018 12:47 PM
Josh88Ford
04-13-2013 09:37 PM
gthbryce
04-06-2010 07:08 PM
beezf350
01-20-2009 12:40 PM
Quick Reply: 6.7 fuel system failure CP4 disaster prevention kit design flaw.
