6.7L Powerstroke Disaster Prevention Kit - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Old 01-11-2018, 02:57 PM
hansenlink
hansenlink is offline
hansenlink is starting off with a positive reputation.
This popped up in my FB. Seems like it may be a good idea. Any thoughts?
https://www.accuratediesel.com/6-7l-...ntion-kit.html
Old 01-11-2018, 03:42 PM
rick danger
rick danger is offline
rick danger is starting off with a positive reputation.
Seems like something to consider after warrantee has expired.
Old 01-11-2018, 04:12 PM
Tom's Avatar
Tom
Tom is offline
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
I'm going to move this to the 6.7L forum since it's engine-specific, and you will probably get some better input down there. Their explanation sort of makes sense, but I'd be curious to see some real-world examples of this successfully preventing injector and line replacement.
$360 plus 4 hours labor would be cheap if it saves the injectors, but I don't think is is a common enough failure to justify.
Old 01-11-2018, 05:45 PM
F250_Super_4X4's Avatar
F250_Super_4X4
F250_Super_4X4 is offline
F250_Super_4X4 is gaining momentum as a positive member of FTE.F250_Super_4X4 is gaining momentum as a positive member of FTE.
Seems like a good idea for 11-14 trucks, in 2015 and higher the failed fuel pump roller was fixed although the pump designation was not, still the CP4.2 with a larger bore and improved roller on the lifter. Using a good lubricity additive to your fuel will greatly decrease fuel pump, injector failure rates.
Old 01-11-2018, 09:28 PM
Troy Buenger's Avatar
Troy Buenger
Troy Buenger is offline
Troy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to behold
The 2015 CP4 pump change was a higher lift cam to increase volume. No other changes were made.
Old 01-11-2018, 09:29 PM
Troy Buenger
My thoughts is this a guarantee to void your warranty if you were to have a HPFP failure.
Old 01-11-2018, 09:31 PM
cappa
cappa is offline
cappa is gaining momentum as a positive member of FTE.
Like you had any to begin with. They'll blame it on water in fuel and you'll pay either way, or make a claim on your insurance
Old 01-12-2018, 07:10 AM
Bugize
Bugize is offline
Bugize is starting off with a positive reputation.
My diesel shop tried to get me to spring for one of these. A net search didnt reveal it happening much. I talked to the service guy at the dealer. The only issues he has seen are from bad fuel or people putting gas in the truck or DEF in the wrong hole
Old 05-17-2018, 11:23 PM
horsecop's Avatar
horsecop
horsecop is offline
horsecop is starting off with a positive reputation.
A bosch fuel pump on a ford engine. Aluminum housing with steel rollers.(pump) Hmmm. The only thing lubing those rollers against the aluminum is today's diesel fuel. Hmmm.
ok, I got nothing. The boy that does all the work on my truck said if anybody does a mode to their truck, putting on the DPK should be the first. Did it! As posted earlier 8k to replace the whole system. That's a low estimate! If you have comprehensive on the insurance your good. But still!
A bosch pump. Man!
Get a kit.
Old 05-18-2018, 07:47 AM
nico963's Avatar
nico963
nico963 is offline
nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.
I stop at my local dealer as they have a “Truck center” and I talk to the diesel mechanic whenever I can.He told me the same thing.Guys putting gas or DEF in the tank is the only reason he see HPFP failures.
Old 05-18-2018, 10:24 AM
Tom's Avatar
Tom
Tom is offline
Originally Posted by horsecop View Post
A bosch pump. Man!
I'm just curious why this is surprising to you. Bosch has been a Tier 1 OEM supplier to Ford and just about everyone else for decades now. Are they not supposed to use a Bosch pump?
The 6.4L PSD used a Siemens injection system.
Old 05-18-2018, 01:47 PM
jav_eee
jav_eee is online now
jav_eee is gaining momentum as a positive member of FTE.jav_eee is gaining momentum as a positive member of FTE.
It injects what?? :O
fordtrks4fr
09-22-2003 05:13 PM
Sedric
01-12-2003 02:37 PM
TexasGuy001
02-05-2002 04:10 PM
NoMo
01-29-2002 08:50 AM
hockeytmc
01-27-2001 10:34 AM
Quick Reply: 6.7L Powerstroke Disaster Prevention Kit
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
