Quick Phenolic Carb Spacer Question
Old Oct 23, 2020 | 07:40 AM
UKPR1's Avatar
UKPR1
So I will be installing this tomorrow to see if it alleviates the fuel boil issue I've been witnessing, and I have a quick question about the plumbing of the fuel inlet pipe. As the line is rigid from the pump to the carb, and the carb is now being raised an additional inch, how does the rigid fuel line how reach the carb's inlet port?
Just trying to plan ahead...
Geoff
Old Oct 23, 2020 | 09:35 AM
Tedster9's Avatar
Tedster9
Welcome to FTE
That might be a problem anytime the geometry is changed. Steel fuel line is easily made up though, NAPA and others sell straight sticks of flared brake like with fittings pre-installed that answer for this.
Old Oct 23, 2020 | 11:37 AM
351Cleveland C4's Avatar
351Cleveland C4
There should be enough slack in the line that you just bend it and stretch it up a little bit.
If not, i usually cut the hard line off down in front of the carburetor and use rubber the last several inches.
Improvise, adapt, overcome
Old Oct 23, 2020 | 11:56 AM
jsc83's Avatar
jsc83
Oooh-rah!
Gunny Highway 2020
Old Oct 23, 2020 | 03:08 PM
wjwolfe82's Avatar
wjwolfe82
I can't remember who said it or find the post but he said...when the boil-over problem occurs...to just turn the key and not touch the pedal.
I've tried it and it works almost every time for me.
Old Oct 23, 2020 | 08:39 PM
UKPR1's Avatar
UKPR1
Thanks for your replies, fellas. Will try manipulating the line and see what I get.
WJ - my issue is that that technique almost never works for me - especially the deeper I get into the boil. Early on - just as the boil begins, the no pedal method works, but 10 mins into it, the throttle needs to be wide open to dump enough air to clear all the fuel that has flooded the throat.
I'll let you know how I make out.
Geoff
Old Oct 24, 2020 | 06:09 PM
UKPR1's Avatar
UKPR1
It was possible to massage the rigid fuel line into its new location. Everything fuel-wise should work out. Looking at the linkage now: I'm taking this opportunity to eliminate the trapeze and install a single rod link, so I think that part is under control, but the issue I am having is with the kickdown rod. It's new higher location makes it want to kick back and stay back (towards the firewall) - a significant amount of force is needed to bring it forward again. What the go-to method for dealing with this? "Reprofile" (bend) the lever up? Or put the mother of all springs to get it to return forward?
Geoff
Old Oct 26, 2020 | 12:53 AM
GaryKip's Avatar
GaryKip
This is from a reply from JEFFFAFA:
The passing gear link (tube) is basically a "L". Short side of it to the carb. Now if you recently put an extra spacer under the carb that kick down tube will be short that amount. Or if you recently replaced a factory 2V carb with a 4V carb and intake it may require a kick down rod extension. Holley part number 20-41. Different intakes set the center pivot of the carb in a different spot.
  • #energyEfficiency .a-icon-popover {display: none; }
    Holley 20-41 Transmission Kickdown Lever Extension
    Price:$11.99 & FREE Shipping on orders over $49.
    Details Details
    • Made of steel with gold irridite finish
    • Accepts transmission kickdown cables
    • Converts 2-barrel carburetors to 4-barrel carburetors
    • Extends transmission kickdown lever
    • Carburetor base bracket mounting style
Let us know how it works.
Old Oct 26, 2020 | 07:11 AM
UKPR1's Avatar
UKPR1
Thanks for that. I think I'll get 2 of them and here's why...
...I think trapeze contraption somehow prevented contact between the kickdown rod and the the pedal linkage. Now that I've done away with the trapeze, there is definitely contact between the new carb linkage rod and the kickdown rod where it begins to sweep down. If I can get the kickdown downturn to start a little further back by using one of your extensions at the carb end, then that should avoid contact there. Then I'll have to use an extension at the tranny end to to make up for the vertical leg height because of the spacer. Might work...might not. But worth a try!
Geoff
Old Oct 28, 2020 | 01:45 AM
GaryKip's Avatar
GaryKip
You may want to check this website out first: /www.kickdownrods.com/
Old Oct 28, 2020 | 08:05 AM
UKPR1's Avatar
UKPR1
Gary - that's awesome that you found this and awesome that there is someone out there doing this. I have reached out to that person this morning for the purpose of having a custom rod made for me. I'll let you know how this one turns out.
Thanks and Regards,
Geoff
Old Oct 29, 2020 | 07:43 PM
UKPR1's Avatar
UKPR1
The 1" phenolic pacer is in. Straight accelerator linked it at the same time as well as putting in a 3G alternator. Some squeal at start up, but that has been improving and only lasts a few seconds. Otherwise starts and idles great. What I wanted to ask was: does having a spacer and running it without an air cleaner make a louder-than-normal hissing or sucking sound (like a vacuum leak)? I initially forgot the crankcase vent hose off the carb baseplate and that made a horrendous hissing sound. Connected that up and 80% of the hiss went away but some of it still remains and it's definitely coming from the carb. Is this now the new normal or is something wrong?
Geoff
Old Oct 31, 2020 | 08:20 PM
JEFFFAFA's Avatar
JEFFFAFA
Different carbs hiss more than others at idle. The hiss is the air and gas the engine is sucking in past the throttle plates at idle. When those throttle plates are just barely open. If you still hear a hiss while above idle, then you have a vacuum leak.
Old Nov 1, 2020 | 10:05 AM
UKPR1's Avatar
UKPR1
Thanks Jefffafa. I ended up going the vacuum leak route as you suggested and started to shoot spurts of brake cleaner. Idle rose behind the carb especially in the region of the vacuum hose. Turns out, how I had the old spacer stacked on top of the phenolic spacer, there was a small gap caused by the protrusion of the vacuum pipe and how it attaches to the baseplate - a gap of about a 1/16th" wide and less than 1" long. I didn't have the proper gasket to seal this off, So I used a smear of gasket maker to seal in, and now the engine has no more hiss.
Thanks for your help!
FordsOnlyGarage
Nov 17, 2018 08:43 AM
ZOOT
26
Aug 14, 2010 02:41 PM
Demian
Oct 31, 2009 03:11 PM
Flathead47
1947 and Older Ford Trucks
Dec 15, 2006 10:47 PM
Bobtailfan
Nov 21, 2005 05:22 PM
