leaking holley carb question
Old Dec 15, 2006 | 08:10 PM
Flathead47's Avatar
Flathead47
I am running dual (2 bb Holley) carbs on a 47 flathead. They run fine but when the engine is shut off the rear carb drips out of the bottom of the carb for a minute then dumps out a few ounces of gas all at one time. Removing the top shows there is still gas in the float bowl, float setting is fine, float and shut off appear good. Anybody experience this problem or have a suggestion? Carbs have been rebuilt and new mechanical fuel pump is regulated to 1 pound pressure.
Old Dec 15, 2006 | 10:47 PM
3Mike6's Avatar
3Mike6
I've seen this before, due to th ilt in the engine...the fuel is tryong to seek an even level.
I beilieve the solution is a check valve on the fuel fuel line between the carbs
Maltman
24
Mar 21, 2014 09:37 AM
sixshootingexp
Dec 2, 2012 10:30 AM
danlee
Mar 18, 2010 10:15 PM
Teagar
Aug 22, 2006 10:39 PM
rmalottwtes30
Jan 13, 2006 10:27 PM
