Stupid question
You could try doubling up on carb-to manifold gaskets to reduce heat into the carb. If your pump's check valves are in good shape, it shouldn't take very much cranking to refill the carb, but it will take some. An electric pump with regulator is likely the most satisfactory solution.
Received 1,344 Likes
on
The gas tank isn't bolted onto 500 lbs of hot metal! I don't remember if 289's have an exhaust crossover in the intake, but I'd bet they either have that or a water passage under the carb area to prevent icing in the winter. It will boil the carb out in 1/2 hour after shutdown on a warm summer day.
Thanks guys,and gal, It will turn over after cranking around a couple of times, but all I can think about is the start up wearing on the engine. It's a new carb from edelbrock with only 10,000 miles on it. I've been disconecting the fuel line and connecting a rubber hose with a funnel to fill the carb bowl. It starts in a heart beat. Just a pain and don't like the risk. Just looking for an easier way. Thanks again
Have you tried stepping down on the gas pedal a time or two before you crank it over? I know this may sound stupid but I got use to driving a fuel injected truck and then bought a carbed truck. It took me a couple times to remember to hit the gas pedal before cranking it over.
If you do add an electric fuel pump make sure to add a fuel pressure regulator. Even if the pump has one built in. Carbs can be sensitive to too much fuel pressure.
on
I put an electric fuel pump on the 292 Y-block in our 60. It sits some times for a couple months at a time. I turn the key on, wait a few seconds to let the pump pressure up, 2 pump of the gas pedal and it starts instantly EVERY time. I recommend the electric pump. However, electric fuel pumps can be dangerous in a wreck, keep pumping out fuel, so you also need to add a collision shutdown. Ron Francis sells them.
Have you ever checked that the float bowl is actually going dry by opening it up? Have you ever looked into the carb throat with the air cleaner off before trying to start it and looking for a squirt of gas to shoot into the carb when you quickly move the throttle linkage manually to full open? Also check for signs of seepage all around the carb, fuel lines and fuel pump. Smell the oil on the dipstick for gasoline odor after sitting for a period of time. Make sure the PCV valve is working.
First, I also have an Edelbrock carb. I know my Carter fuel pump is good, but if I don't drive the truck for 4 or more days, the same thing happens, the gas seems to back flow to the tank.
Sometimes there is enough left in the bowl to get a squirt out of it from the accelerator pump if I floor the gas pedal before starting.
But if your concern is grinding the engine over for a little longer to get the gas up to the carb to start it up, don't be concerned. If your starter and charging system are working properly, it is probably BETTER that you are turning it over a little longer after sitting for awhile.
That 20 extra seconds also pre-oils the engine (sends oil up where it hasn't flowed for awhile) and is much better for your engine after sitting that to have it fire right up.
As a matter of fact, I deliberately wired my starter button to be able to turn over the engine without the ignition on just for that purpose.
Best start up procedure is to floor the pedal while pulling out the choke cable half way, then release the pedal and crank it up. If that doesn't work then floor the pedal a second time the next time you start it up.
