1978 - 1996 Big Bronco
distributor gear swap
Old Oct 22, 2003 | 03:35 PM
Kemicalburns's Avatar
Kemicalburns
So anyone know if its even possible to swap the gears on a distributor or do i need to send it in to have done.
thanks
Old Oct 22, 2003 | 06:57 PM
greystreak92's Avatar
greystreak92
Kem,
Can't recall...is the dist. gear pressed on or is there a roll pin holding it to the shaft? If its a roll pin, you should be able to carefully drive it out, swap a new gear and replace the pin. If its pressed, well, unless you have that kind of cool stuff in your garage, I'd take it to someone who does.
Old Oct 23, 2003 | 01:11 AM
Steve_Uzi's Avatar
Steve_Uzi
The Dizzy gear on my 460 dizzy is pressed on and a roll pin. A new gear will come with new roll pin. You can do it yourself, you don't need a fancy press, just a way to support the gear as you tap it off and on.
You need to make sure that you position the new gear in the right location, otherwise you won't get the correct mesh to the cam gear and the dizzy gear will get chewed up.
Old Oct 23, 2003 | 09:27 AM
Kemicalburns
well i called a local shop and he said 40bucks to remove the gear from my 95 distributor and put it on the 91unit.
FatherDonald74
Jan 7, 2015 11:37 AM
1990-f250
Mar 24, 2014 08:54 AM
daboot
Jun 1, 2009 07:14 PM
pc_2000
Jun 12, 2008 02:45 PM
64fordf100292
Mar 16, 2007 04:11 PM
