94 distributor
Old Jun 1, 2009 | 04:39 PM
daboot's Avatar
daboot
94 distributor
i did an efi 302w /94 efi 351w swap in a 86 f150 I dont have the means to do a distributor gears swap, so i was wondering if it we possible to rewire a 94 351w distributor to work in the 86
Old Jun 1, 2009 | 04:43 PM
andym's Avatar
andym
Your post is a little hard to follow, so let me ask this: Your truck is a 1986 F-150 that originally came with an EFI 302, right? And now you've swapped in a 94 EFI 351w, right? Why won't the distributor that came with the 351 work? What parts of the new engine did you swap over?
Old Jun 1, 2009 | 04:54 PM
daboot's Avatar
daboot
the 94 dist is for fender mount module. the 86 is dist mount module
Old Jun 1, 2009 | 04:56 PM
andym's Avatar
andym
You can't mount the module on the fender? Worst case scenario, just buy a distributor for an '88 F-150 with a 351w.
Old Jun 1, 2009 | 05:13 PM
daboot's Avatar
daboot
problem is the 94 is a roller motor = steel gear. Cant find a distributor with steel gear that also has a module mount
Old Jun 1, 2009 | 06:46 PM
fellro86's Avatar
fellro86
How about taking the fender mount and making a stand on the motor?
Old Jun 1, 2009 | 07:14 PM
dustybumpers's Avatar
dustybumpers
knock he pin out of the gears, pull them off, switch them, put the pin back in, no more problem
Oxfordrider
Jul 11, 2014 11:11 AM
lvin4jc
25
Jul 6, 2011 07:07 PM
barca_texas
Mar 23, 2005 03:15 PM
akita
Jul 29, 2002 06:54 PM
CantDrive55
May 18, 2001 04:05 PM
