02 7.3 won't shift
Old Oct 21, 2020 | 07:37 PM
Shawn Kennedy's Avatar
Shawn Kennedy
02 7.3 won't shift
Hi everyone I recently pulled my 4r100 tranny because reverse had gone. Everything els worked still worked. You could drive the truck just fine . Just couldn't back up. I replaced the reverse steels and fibers which were welded together. After I put everything back together and bolted back into truck I had fixed the reverse problem but the truck won't shift anymore. All my gears work on gear selector. But when put in drive it won't do more than 30kmh. I pulled my shift solinoid and tested it and it seems fine. Pull main valve body and checked everything seems fine. Please help
Old Oct 21, 2020 | 07:39 PM
Shawn Kennedy
Sorry truck is a 2002 f350 7.3 4x4
Old Oct 21, 2020 | 08:21 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What codes are stored in the computer's memory?
Old Oct 21, 2020 | 09:09 PM
Shawn Kennedy
There are no codes coming up
Old Oct 21, 2020 | 09:58 PM
Mark Kovalsky
What are you using to read codes?
Old Oct 21, 2020 | 10:13 PM
Shawn Kennedy
It's a cheap reader from princes auto. It's not capable of reading tranny numbers .
Old Oct 22, 2020 | 03:36 PM
Mark Kovalsky
You need to read transmission codes to fix this. Without knowing the codes all I can tell you is to fix what's wrong.
96 OBS
6.7L Power Stroke Diesel
Sep 11, 2020 11:06 PM
Walwal44
Feb 2, 2015 05:12 AM
JaySVX
Nov 1, 2014 11:41 AM
M.Stephens
Mar 22, 2005 12:44 PM
TUFFY
Aerostar
Jan 10, 2005 11:16 PM
