Accelerator pedal compatibility question
Old Oct 21, 2020 | 06:42 PM
wheelerfreak's Avatar
wheelerfreak
After checking the codes (P2106 and P2135) and trouble shooting the possible results I have a bad pedal sensor. MAF, TPS and throttle body are reading good. Installed a new TPS and cleaned the MAF anyway. I'm getting wonky readings from the pedal so I will replace that. I can only find replacement pedals for an F150 with fixed pedals, I have adjustable pedals. What are the differences if any in the two types of pedals themselves and can I use the fixed pedal assembly? The mounting looks the same and they look like they have the same 7 pin connectors.
Old Oct 25, 2020 | 01:21 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Can you get a part number off of the current pedal?
. . . or can you have a dealer look up the part number for a fixed and an adjustable pedal and see if there is a difference?
aklim
Mar 11, 2019 05:00 PM
Iasphynx
Feb 28, 2013 08:08 PM
kat6770g
Oct 16, 2011 12:46 PM
dixokai
Oct 8, 2009 09:08 PM
seanlleiker
Mar 20, 2009 01:03 PM
