throttle pedal not working
Old Oct 14, 2011 | 04:38 PM
kat6770g's Avatar
kat6770g
Ok I have a 2003 ford f350 6.0. It is throwing throttle pedal codes. We replaced the ICP and put on a new trottle pedal. The new throttle pedal will not accelerate at all. You can put on the old one and it will work but throws the codes. We thought that it may have be a defective pedal so we returned it and got another one. It still is not working. Does anyone have any thing that may help PLEASE..................
Old Oct 14, 2011 | 05:03 PM
00GT's Avatar
00GT
I'm sure some one in the correct forum could help you out.
Old Oct 14, 2011 | 07:43 PM
TaborCT's Avatar
TaborCT
hmm did you replace the throttle position sensor?
Old Oct 15, 2011 | 12:31 PM
kat6770g's Avatar
kat6770g
yes the sensor is on the throttle pedal. Could there be another one somewhere
Old Oct 15, 2011 | 12:41 PM
kat6770g's Avatar
kat6770g
2003 ford f350 6.0 throttle pedal not working
I have a 2003 F350 6.0 that is giving me fits. It was throwing throddle pedal codes. So this is what we have done so far checked all the wiring, replaced the icp sensor, put in not 1 but 2 new throttle pedals and nothing still. The old throttle pedal will accelerate but it throws codes. The new throttle pedal does not throw codes but will not accelerate. Can somebody tell me what we are doing wrong or could it be something else.
thank you
Old Oct 15, 2011 | 04:56 PM
TaborCT's Avatar
TaborCT
sound like a defective pedal then. where are you getting the from?
Old Oct 16, 2011 | 09:28 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Moved from 97-03 forum.
Welcome to FTE kat.
Old Oct 16, 2011 | 12:46 PM
NewToDiesels's Avatar
NewToDiesels
Do you have any extra gauges so you could see the HPO pressure when she's running? There's a slight possibility the HPO system may be causing your issue when you have the pedal that's not throwing codes installed in the truck.
aklim
Mar 11, 2019 05:00 PM
AGrayson84
Nov 8, 2016 02:56 PM
Peterbilt376x
Dec 3, 2014 07:10 PM
HighOctane
6.4L Power Stroke Diesel
Jul 31, 2014 07:29 PM
95STROKER29
Feb 25, 2008 10:43 PM
