Throttle pedal ?
Old Oct 8, 2009 | 09:46 AM
dixokai's Avatar
dixokai
Throttle pedal ?
I'm still learning all the characteristics of this truck I bought a few weeks ago and I have a question about the throttle pedal. When I bought this truck I noticed I had to move the throttle pedal about 1/2 to 3/4" before I got ant response from the engine. It bothered me at first but now I am kind of use to it. Every time someone else drives my truck they mention that to me and it has got me thinking "is this normal?"
It also gives the impression that it needs a lot of throttle to keep 75 mph on the freeway. I gave up a 6.9 IDI for this truck and just the weight of my foot would get a response out of that one. I know these are two different animals but it sure takes some getting use to.
How are all of your trucks, and if this is not normal, how do I fix it? Is there an adjustment? I couldn't see one at a glance.
Thanks
Old Oct 8, 2009 | 09:57 AM
Talyn's Avatar
Talyn
Yea, that is normal.
I was annoyed at it at first. But I like it.
You can do the hotfoot mod which fixes that, but requries some modificatinos to the pedal assembly because its fly by wire.
I'm still trying to figure out what signal it sends to the engine in that "null" point, cause the engine sounds different, but its no power. Maybe just sending a little more fuel or something.
As for the pedal on the freeway.
No idea.
Old Oct 8, 2009 | 10:00 AM
Hussler's Avatar
Hussler
On the go pedal there are two items.
1. TPS = throttle position sensor
2. IVS = idle validation switch (2 wire connector)
When you push on the go pedal the IVS should disengage. Look under there and you will see a metal tab that hits the switch. That tab might be bent so you have to push the pedal more than normal for it to disengage.
Old Oct 8, 2009 | 01:46 PM
strokin'_tatsch's Avatar
strokin'_tatsch
^^^ the TPS is on the top of the pedal and the IVS of course on bottom. the IVS makes a clicking sound when it disengages. this is the switch losing connection with the tab he is talking about. if you bend that tab out(towards your seat) with a pair of pliers til the IVS clicks AS SOON as you touch the pedal then that will help out A LOT with that pedal. the dead 1/2-3/4" of pedal is normal unfortunately, but we can fix that rather easily by doing what i told you
Old Oct 8, 2009 | 02:29 PM
Hussler's Avatar
Hussler
If your turbo is not spooling up properly you will have to give it a lot of throttle to keep it going. When I first got my truck I experienced what you are describing. One day I took off the MAP sensor hose and blew into one end and a big chunk of gunk came out. I immediately noticed when I was on the freeway I had to actually give it much less throttle to keep speed up. And I could actually hear my turbo spool. Anyway, just a thought and an easy fix.
Old Oct 8, 2009 | 09:08 PM
dixokai's Avatar
dixokai
Thanks for the advice guys, I will look into it as soon as I get the chance. I usually run about 2 1/2 to 3 pounds of boost at 75 and around 5 pounds on the slight inclines. When I pin the skinny pedal boost jumps up and the truck gains seed. It just seems like I have to hold it down to far to keep speed but I will definitely check the MAP sensor line. (Free fixes are a good thing). Just finished ditching a K&N filter and installing a 6637 mod. Wish I would have checked this thread BEFORE I went out in my shop!
DSMMH
Jan 23, 2013 08:12 AM
tfdcapt
Apr 20, 2008 12:59 PM
Jharger
32
Oct 3, 2005 12:03 PM
cleanLX
May 19, 2004 02:36 PM
csherman4383
Mar 27, 2004 02:13 PM
