Build specs?
Old Oct 20, 2020 | 02:25 PM
Corlyn Brown's Avatar
Corlyn Brown
Build specs?
rings gap?
connecting rod gap?
rod and main journals parameters?
bearing clearances?
Old Oct 20, 2020 | 06:07 PM
Visurveyor's Avatar
Visurveyor
Don't want much considering you haven't sad what year it is.
Old Oct 21, 2020 | 05:44 AM
Corlyn Brown
Wink
I figured either version would work.
Old Oct 21, 2020 | 06:23 AM
SmackDaddy's Avatar
SmackDaddy
Do you know your year model? Post it so someone can help you or find the information yourself by researching.
Old Oct 21, 2020 | 01:33 PM
Corlyn Brown
I've spent so MANY HOURS trying to find it isn't funny! I don't ask forums until exhausted other resources. Mostly because you can get bad information.
Tech folder was great for torque specs but zero help with clearances.
6.4, 7.3 & International I found some data on the ring gaps. Since can grind to what ever I want going in between the tightest range combining all 3
Example: top ring range is .014- .024 (7.3) .014-.024 (6.4) .011-.022 (internantional) So I'll set mine to .014-.022
Mains I found .0008 .0034 on youtube via a oral statement (6.0doctor) but no official documentation.
Rods found nothing????
Even called ford dealers, indepandent shops and emailed a bunch of both all over the country!
Old Oct 21, 2020 | 01:41 PM
SmackDaddy's Avatar
SmackDaddy
My machinist had a book with all of these tolerances etc. I was there as he did some of the work and somewhere I have the paperwork showing all measurements of my block before and after machining.
You need to call a good machinist and see if he has time to look this up for you.
Go to 6.0 Doctor’s website. Call him, I spoke to him a few times when shopping for new o ringed heads a while back. I would post a link but this forum won’t let me.
Old Oct 21, 2020 | 01:57 PM
ford390gashog's Avatar
ford390gashog
Here try this.
File Type: pdf
Old Oct 21, 2020 | 02:30 PM
TooManyToys.'s Avatar
TooManyToys.
Old Oct 22, 2020 | 04:15 AM
Yahiko's Avatar
Yahiko
I have the Ford building info on DVDs for all the years of the 6.0L
preppypyro
Mar 18, 2019 10:16 PM
Daniel92f250
Dec 17, 2013 09:11 PM
Schickel
Sep 10, 2012 05:53 PM
gman7785
May 30, 2002 12:29 PM
jowilker
Jun 22, 2000 09:51 PM
