rod bearing
Old Dec 4, 2013 | 11:21 PM
Daniel92f250's Avatar
Daniel92f250
rod bearing
Why is one of my rod bearing screaming I have a 351w
Old Dec 5, 2013 | 12:34 AM
85e150's Avatar
85e150
Welcome to FTE.
How do you know it's a rod? Usually you don't hear much other than a knock--if there is enough friction to cause a screech, they usually sieze and break the rod, sawing the block open with the remaining piece spinning around in there.
Old Dec 5, 2013 | 11:48 PM
Daniel92f250
It was knocking and now it is screech
Old Dec 6, 2013 | 12:20 AM
85e150's Avatar
85e150
Time to tear into it. You may be able to save the rod, but it will need to be resized and the crank turned at this point. If it breaks, the whole engine is junk.
Old Dec 6, 2013 | 11:17 AM
baddad457's Avatar
baddad457
Probly the # 4 or 8 rod. Those are the last in line to get oil. Keep running it and it'll stop. Only then you'll have a hole in the block, if lucky only a broken rod jammed inside the block. Plus the crank is likely damaged beyond turning to repair it.
Old Dec 6, 2013 | 05:45 PM
Daniel92f250
what if I just put a new engine in my truck and be done with it don't have to worry about refurbishing a cranker nothing like that :-)
Old Dec 6, 2013 | 09:42 PM
joey2fords's Avatar
joey2fords
that will do the job.
Old Dec 17, 2013 | 09:11 PM
bra$$monkey's Avatar
bra$$monkey
I kept running mine - didn't get a hole in the block but had a really cool dent in the oil pan : }
RydeMyToy
Modular V10 (6.8l)
Dec 16, 2013 03:47 PM
stainlessstroker95
Jun 1, 2011 08:00 PM
FERacing66
Nov 7, 2004 12:49 PM
brett_d
Apr 14, 2004 11:03 AM
jowilker
Jun 22, 2000 09:51 PM
