Track Bar Mount.
Old Oct 20, 2020 | 10:25 AM
bakerbuilttracks's Avatar
bakerbuilttracks
Track Bar Mount.
Can someone post a photo of the bottom track bar mount. Where the Bar connects to the axle.
Looking to see what the STOCK setup looks like.
I bought my truck in 2006 and the PO has an add a leaf on the front spring pack. There are 3 springs instead of two. Also the lower Track bar mount has black paint peeling off it revealing a Red paint under it. Im assuming when the PO installed the springs he got a bottom bracket for the track bar to relocate it.
Long story short I'm looking to replace the springs, they are shot and was looking to get the X code or High Arch X codes i spoke with ATS about.
Basically wondering if i will need to purchase an adjustable track bar as well.
Old Oct 20, 2020 | 12:19 PM
ESwift's Avatar
ESwift
CNCFAB
Old Oct 20, 2020 | 12:23 PM
ESwift's Avatar
ESwift
CNCFAB
I have not seen too many people relocate the trac bar mount at the axle connection, most spring kits give an extended upper mount for it. On just a leveling spring addition that itself isnt always needed. On higher front lifts most utilize an adjustable track bar.
If you have a different then stock bracket at the axle, it is very likely its an aftermarket one that replaced the oem one that may have broken (not uncommon)
Old Oct 20, 2020 | 02:40 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
ESwift, E99, Egads, where's your steering stabilizer?
Your bracket where it should be is all bent up.
What socket size is the flange bolt head on the lower bolt of your track bar? (where it mounts to the axle bracket in question).
The lower track bar to axle bracket bolt on my 2000 appears to have a larger bolt head size than yours. I went out and did what I am asking you to do, and found that my lower track bar bolt takes a 30mm socket.
What I don't know is if this is due to a design update for vehicles built on or after 3/21/1999, or if this is due to my truck being an F-550, as there a couple of linkage differences between 450/550 chassis cabs compared to 250/350 counterparts on otherwise similar front ends.
Old Oct 20, 2020 | 02:43 PM
ESwift's Avatar
ESwift
CNCFAB
Had no stabilizer on it when I bought it, amd I havent gotten to it yet​​​
I will check the bolt size on my e99, I can check on my 2000 as well. I know they revamped the bracket at some point in 99, I believe to lift the sway bar up an inch.
I believe the 2000+ had a 1" diameter trac bar as well vs the earlier 3/4" that you see in my e99 pics
Old Oct 21, 2020 | 11:06 AM
bakerbuilttracks
Thanks guys
YEP mine looks NOTHING like that.
I will try and get a picture tonight and post it.
Eswift can you get one of your 2000 model truck .
My build date was 6/99 on my door sticker.
Old Oct 21, 2020 | 11:16 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
[utag=member.php?u=482071]bakerbuilttracks[/utag] There are a number of aftermarket fabrication companies who have designed and reproduced weldable bracketry to repair or replace the OEM track bar mounts that tear apart with lifts.
If you post a photo of your lower track bar bracket, some of us might be able to tell you right away if it is an OEM or an aftermarket weld on bracket.
Old Oct 21, 2020 | 02:36 PM
bakerbuilttracks
Awesome
will do , i will try and get the photo tonight.
Its not my DD anymore just my weekend toy mover LOL
Old Oct 21, 2020 | 03:03 PM
ESwift's Avatar
ESwift
CNCFAB
Originally Posted by bakerbuilttracks
Thanks guys
I believe the model 2000 I have looks the same, minus the track bar bolt head is bigger. That axle is off my 2000 5.4 f250 I plow with, and the axle that is on that plow truck is off my 2000 7.3, (swapped the 7.3 from 3.73 to 4.10) and that axle came off another truck acording to the previous owner (friend front flipped, only original parts left at this time are, main engine block, zf6, hood, frame.....).
Regardless, they all look the same, I will get pics of plow truck, the 7.3 has been being borrowed by my friend for 3 months. His 2003 7.3 is here waiting a zf6 swap, I can look at that track bar mount as well
Hope all that didnt give you a headache 🤣 🤕
Old Oct 22, 2020 | 09:26 AM
bakerbuilttracks
Here is what I got
Old Oct 22, 2020 | 09:33 AM
bakerbuilttracks
Old Oct 22, 2020 | 09:40 AM
ESwift's Avatar
ESwift
CNCFAB
To me that kind of looks like an add on bracket that just bolts onto stock mount and then lets the bar mount higher?
is it removable to use the stock mount?
I would say if you can, you shouldnt need to spend the money on an adjustable trac bar. I am not a fan of them.
I have x codes with 2or3 added leafs on the front of my service truck, I am using all original track bar and mounts, I do have the lowered upper track bar mount that came with the add a leaf kit, but I didnt need it(I didnt use all 5 added springs)
Old Oct 22, 2020 | 11:13 AM
pirate4x4_camo's Avatar
pirate4x4_camo
your stock lower track bar mount is intact. somebody added the extension.
if you can post a pic from the front looking back that shows the relationship of the track bar to the tie rod as well as a pic of your upper tack bar mount and the pitman arm.
the reason being the track bar and tie rod must be parallel or you will get bump steer, this is typically done by using a drop upper track bar mount and a matching drop pit man arm.
me thinks with your modified lower mount the track bar and tie rod are no longer parallel and you will want to correct this by removing that extension and either using a longer track bar or lowering the upper track bar mount and pitman arm. which one you can use or will need to do will be dependent on the working angle of the tie rod ends.
Old Oct 26, 2020 | 10:05 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
@ESwift , my 2000 F-250 did not have a stabilizer when I bought it either and the U-shaped mount looked like yours. I was able to use a pry bar and a large crescent wrench to bend it back into shape. A friend of mine from my previous profession was installing a dual stabilizer setup on his truck, so he gave me the OEM stabilizer parts off his 2003 for free. I bought a Bilstein stablizer and have been good since.
@bakerbuilttracks , there is a thread in the 7.3L PSD Tech Folder that has some more details and images that may be of use to you during your project. I have linked it below for quick access.
https://www.ford-trucks.com/forums/1...l#post13812037
crucialprospect
May 23, 2018 05:26 PM
Dart340w2
Sep 24, 2013 04:44 PM
SpectreZ91
18
Dec 4, 2008 04:52 PM
basstardo
Jul 15, 2005 03:51 PM
RRMike
Sep 16, 2004 06:28 AM
