PO234 OVERBOOST CODE
Old Oct 19, 2020 | 11:24 PM
nburleson1's Avatar
nburleson1
8th Gear
While towing, after topping a hill I noticed my exhaust brake went off and I wasn’t the one who turned it off. I tried to turn it back on and it just blinked at me a few times. After that I read my codes on my EZLYNK Autoagent 2.0 the PO234 overboost code was showing. No check engine light but the truck wouldn’t boost over 14-15 PSI. I usually boost 30PSI+. I could still run 80MPH down the freeway no problem but the truck did have significantly less power. When I got to where I was going I cleared the codes and it’s been running normal ever sense. What kind of problem could I have going on? TIA!!
Old Oct 20, 2020 | 04:48 AM
Just Strokin's Avatar
Just Strokin
Possible turbo problem with the vanes??? Contact a dealer with your VIN and mileage and see if you are covered under the PowerStroke warranty.
Old Oct 20, 2020 | 09:59 AM
nburleson1's Avatar
nburleson1
8th Gear
Thank you for chiming in, my pickup is deleted and tuned with GDP tunes so my warranty is gone. If I have a turbo problem I will probably go with a non VGT from MPD but my concern is that I don’t want to have the same problem after getting a new turbo. Any other possible problems that I could take a look at and hopefully get it pinpointed? Thanks!
Old Oct 20, 2020 | 07:12 PM
kper05's Avatar
kper05
I think, based on my testing with the gen1 turbo which doesn't handle high boost long term, you need a lower HP calibration that doesn't allow higher boost. I don't know much about the gen2 turbo on the 2016 to know how much boost is safe all the time such as pulling a long grade.
Normally you would work with GDP to see what is happening but no idea if they'll even talk with you at this point for a non-emissions pickup.
Old Oct 21, 2020 | 07:30 PM
Painted Horse's Avatar
Painted Horse
I got that code once on my 2015 truck. Pulling up a 7% grade in July at 100° towing a load of horses.
It shut the truck right down. I coasted to the side of the road. Pulled the code and called the dealer. They told me it was an overboost and there was a flash that would adjust the sensor so it wasn't as sensitive.
I cleared the code. Drove that weekend and took it in the next week. They flashed the latest software and everything was good after that,
Old Oct 21, 2020 | 07:41 PM
nburleson1's Avatar
nburleson1
8th Gear
Thanks for the info!
Old Oct 21, 2020 | 08:33 PM
Just Strokin
Hope you don't plan on going to the dealer to have them flash your truck since you are deleted.
sgrol
6.7L Power Stroke Diesel
34
Sep 3, 2024 10:38 AM
bakerbuilttracks
Sep 19, 2013 11:01 PM
simsbud
Jul 10, 2011 03:04 PM
duck fan
17
Jan 5, 2011 11:29 PM
renyren
Jun 20, 2010 08:13 PM
