Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
P132B - Turbocharger Boost Control A Performance
Old 07-07-2017, 09:15 PM
sgrol
sgrol is offline
sgrol is gaining momentum as a positive member of FTE.sgrol is gaining momentum as a positive member of FTE.
I have searched and searched but can't find much on this code as it applies to the 6.7 engine. I first encountered this code when pulling my toyhauler a couple of weeks ago. Leaving the camp site I noticed the truck would not build normal boost or power so I pulled over and pulled the P132b code. I reset codes, drove away under normal power and boost, and was fine until today. Today, I was on trip from S TX with truck (no trailer) and noticed boost was on low end. No noticeable performance issues but, again, I was not pulling. I later noticed engine light was on. I continued driving until home and pulled code P132b again before shutting engine off. When I reset the codes I heard turbo action from exhaust. Sounds like vanes close, build up back pressure, then open releasing the back pressure with a hiss heard from the exhaust. I hear this all the time when I first start up. Am I about to lose my turbo? Anything I can check, clean, or replace before this leaves me on the side of the road? I am siting right at 140,000 miles, regular oil changes at 5k miles, Rotella 15-40, deleted and tuned to lowest setting and drive like a grandpa which I am.
Old 07-08-2017, 07:29 PM
sgrol
sgrol is offline
Nobody has a clue on this? Pretty much what I found searching this code.
Old 07-08-2017, 07:37 PM
EO2SeaBee's Avatar
EO2SeaBee
EO2SeaBee is offline
Proudly Deplorable
EO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputation
Looks like it was a common topic of discussion across multiple threads in multiple forums for the 6.0's. I didn't find anything in searching where it was discussed in a 6.7, so it must not be that common these days. I would guess it is caused by similar circumstances though, and remedied similarly as well.
Old 07-08-2017, 07:43 PM
sgrol
sgrol is offline
Thanks Doug. I found the same thing re the 6.0. Trying to determine if I have a turbo on its way out or an errant sending unit.
Old 07-08-2017, 08:12 PM
EO2SeaBee's Avatar
EO2SeaBee
Proudly Deplorable
Good luck with the repairs Steve. Maybe it is just a gunked up VGT ring, or a fouled sensor that can be inexpensively repaired or replaced, rather than needing a new turbo.
Old 07-10-2017, 01:01 PM
defekticon's Avatar
defekticon
defekticon is offline
defekticon is gaining momentum as a positive member of FTE.defekticon is gaining momentum as a positive member of FTE.
This happened to me a two months ago. Simply turning the truck off, clearing the code, then back on fixed it. I reached out to a Ford diesel tech on youtube who makes outstanding videos (flmmaz).
He confirmed what I suspected. It can either be a stuck VGT solenoid, VGT ring or the turbo can be on it's way out.
The VGT solenoid is buried in there with the turbo charger and not easy to get to. As I understand it Ford did not issue instructions to clean the VGT Ring as they have on the older 6.0 VGT Turbos. It's a replacement if you take it to a Ford dealer, but they would at least be able to diagnose it.
My p132b code hasn't returned in two months since I first saw it. I've been towing my TH quite a bit since then. I do expect that I'll be replacing the turbo eventually, hopefully on my terms rather than on a flatbed.
Old 07-13-2017, 09:56 PM
sgrol
sgrol is offline
Happened to me again three times this week after a lot of idling and stop and go driving. All I have to do to remedy is erase codes. If it was something stuck I don't see how resetting the codes would fix it. I am going to pull and clean the MAP sensor to see if it helps.
Old 07-15-2017, 07:00 PM
sgrol
sgrol is offline
I pulled the MAP sensor and cleaned it with electronic cleaner spray. It had a good bit of gunk on it. Installed it and the boost read about 38 psi with just the key in the on position. Started it and check engine light was on with the boost reading the same 38 psi. So, I bought a new one and all is fine with the boost gauge and engine light. Only time will tell if this has solved the P132B code. More to come.
Old 07-20-2017, 08:33 AM
sgrol
sgrol is offline
Code and no boost are still occurring with new MAP sensor. Back to the drawing board.
Old 03-26-2018, 08:46 AM
nhoffman94
nhoffman94 is offline
nhoffman94 is starting off with a positive reputation.
Did you ever solve this issue? I have a 2011 with 80,000 miles. Its our shop truck and is doing the same thing although I rarely have a lack of power. Typically its a turbo however my VGT solenoid does work and the truck runs just fine most of the time. That said we mainly haul a single car trailer with it which is fairly light. I've installed a new MAP as well however havent confimred the fix yet. Just curious as to what you ended up doing.
Old 03-26-2018, 09:00 AM
defekticon's Avatar
defekticon
Not that it's an option for everyone - I went with a DPF delete and a conservative no-smoke tune, never had another problem with it. Truck can idle all day long without any problems with boost performance. Which leads me to believe it's a electronic emissions control issue (EGR/DPF/etc) somewhere and NOT a problem with the turbo charger or VGT solenoid. I'm also 100% certain at this point if you have a 2011 truck, and delete the emissions equipment you don't have to worry about the turbocharger failing as prominently since you're cutting the heat going through the turbo by an order of magnitude. I put a real EGT gauge on my truck and the before/after cruise EGT's went from 800-900 degrees (Measured at the factory Downpipe location) to 400-500 degrees (Measured at the EGR fitting in the passenger Exhaust manifold). As long as you're not running race tunes over-spinning the turbo to get higher boost pressure, reducing the heat alone should extend the life of the ceramic ball bearings in the 2011 turbocharger. The only time I see EGT's over 800-900 degrees is when I'm pulling a trailer.
Old 03-30-2018, 05:04 AM
golfmedik's Avatar
golfmedik
golfmedik is offline
golfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputation
I've just been through the same thing as apparently I've had a stuck VGT for quite a while. My '13 got a new turbo, EGR cooler, MAP sensor, wastegate and solenoid, both coolant flushes, oil change and within 80 miles, the engine light was on and the boost gauge hung at 4. The MAP sensor was the culprit as it had gotten a piece of junk stuck in it. So, the dealer didn't have a new one so they put my old one back in until they could get another. I drove the truck for two days without a problem and the new MAP sensor was put in last Friday morning before going camping. During our trip, the truck basically went into limp mode, no power and no boost. Got it back to the dealer and the tech looked it up and it came down to when I changed the MAP sensor in the truck on Friday morning. With the computer already reading the info supplied by the sensors, it got really confused by installing a new MAP. All the tech did was use the IDS to clear the "specified functions" in the PCM and the power came back at turning the switch on. I've got FORScan now on my phone and have bought the bluetooth dongle to be able to reset the specified functions with my cell phone app if I have to change another MAP sensor.
Old 03-30-2018, 09:00 AM
defekticon's Avatar
defekticon
Thanks Golfmedik, that's good info. I'm planning on replacing the turbo in my truck before it leaves me on the side of the road since it's a 2011. I only have 56,000 miles on my truck and haven't had any other issues except for this p132b code which had me afraid I would have been replacing the turbo at 35,000 miles when it first showed up. I wanted to replace it this summer, but I'm moving to FL from MD and closing on a house so it's gonna have to wait. The good news is the weather down there makes replacing the turbo during the winter a good idea! Will make a good "winter" project.
Old 06-24-2018, 07:24 PM
eberflus911
eberflus911 is offline
eberflus911 is starting off with a positive reputation.
Code
hey so did doing this fix your problem and you havent had any more issues with it? Im having same thing going on on a deleted 2015.
Old 06-24-2018, 07:26 PM
eberflus911
did you ever get your issue fixed?
Quick Reply: P132B - Turbocharger Boost Control A Performance
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
