Check engine
Old Oct 14, 2020 | 07:26 PM
Mr. Rogers's Avatar
Mr. Rogers
Check engine
Shows lean. Every time this happens I cleans the mas sensor and it’s good for about 4-6 tanks. Thinking it might be time to change it. Thoughts? Texas has has a lot of ethanol.
Old Oct 14, 2020 | 11:13 PM
Spaznaut's Avatar
Spaznaut
What is the actual code? Both banks lean? Just one bank lean?
Old Oct 15, 2020 | 07:22 AM
projectSHO89's Avatar
projectSHO89
Almost everybody has lots of ethanol. It isn't your problem.
Provide explicit details like codes (as mentioned) and your vehicle specifics. We ain't psychic.
Old Oct 15, 2020 | 09:22 AM
alloro's Avatar
alloro
Lean conditions can also be caused by a vacuum leak.
Old Oct 15, 2020 | 06:29 PM
Mr. Rogers's Avatar
Mr. Rogers
Lean
98 navigator both banks lean. Sorry for lack of information. I work a lot
Old Oct 16, 2020 | 10:56 AM
alloro's Avatar
alloro
That's okay, you're still welcome in "The Neighborhood."
At the back of the upper intake there is a rubber elbow that supplies vacuum to the PCV system. This elbow is a known issue for cracking and causing a vacuum leak.
Old Oct 16, 2020 | 02:18 PM
Mr. Rogers's Avatar
Mr. Rogers
Thanks
I’ll just change it as well. I’ve changed out most of the rubber now.
Mauro Martinez
2009 - 2014 F150
May 2, 2020 07:04 PM
ocala562
1997 - 2003 F150
Jan 20, 2011 05:10 PM
blieux1
1997 - 2003 F150
Feb 24, 2007 11:14 AM
Petrol
Modular V8 (4.6L, 5.4L)
Jan 10, 2003 06:23 PM
