p1299 CHT Sensor.
Old May 1, 2020 | 05:21 PM
Mauro Martinez's Avatar
Mauro Martinez
p1299 CHT Sensor.
hi guys, I need some help. I have a 2009 f150 stx 4.6 300k
Today check engine came in p1299. I replace the sensor near the front of the engine, behind the alternator, but still not running. Any other idea? there is another sensor?
Thanks!!!
Old May 1, 2020 | 11:58 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Okay so it won't start and has this code?
When it started having this code was it running?
Did it overheat?
Does it turn over but not fire?
We're going to need some more information in order to assist.
Old May 2, 2020 | 08:18 AM
alloro's Avatar
alloro
I think you replaced the coolant temperature sensor (CTS) for the dash gauge. The CHT is located under the intake manifold about halfway back on the head.
Old May 2, 2020 | 09:31 AM
gDMJoe's Avatar
gDMJoe
Question
Mauro Martinez ... 2009 f150 stx 4.6 ...
2V or 3V?
HINT/TIP: Put your -complete- vehicle information (year, model, cab, trim, engine, wheelbase, _x4 drive, mileage, modifications, etc., etc.) in your signature -OR- provide it in your posting(s).
Old May 2, 2020 | 04:45 PM
Mauro Martinez
It was running. Stopped at grocery store and went to my house and before I arrived stop running. Could not make it run again. Check engine was on because a p430 (catalyst below.....blah, blah) and p1299. Did not notice any overheat. Turn over, but not fire (like no fuel)
When I removed yesterday the injectors and manifold almost no gas in there. It could be the fuel pump?
Gonna be checking the overheat and the thermostat.
Old May 2, 2020 | 04:47 PM
Mauro Martinez
I'll be removing the manifold tomorrow. I want to clean it up very well. I'll be locking for it. Also saw the knock sensor.
Thanks.
Old May 2, 2020 | 04:48 PM
Mauro Martinez
Originally Posted by gDMJoe
2V or 3V?
I believe is a 2v. f150 2009 stx 300k
Old May 2, 2020 | 05:39 PM
Mauro Martinez
This is the sensor that I replaced.
Old May 2, 2020 | 07:04 PM
CathedralCub
FTE Community Team
Yes, it could. You should probably check fuel pressure before you get too deep into it.
JOHN2001
Aug 9, 2012 09:21 PM
eman_00
6.4L Power Stroke Diesel
Nov 29, 2010 07:15 PM
gregj
1997 - 2003 F150
Nov 1, 2004 05:06 PM
marivera
1997 - 2003 F150
Jun 24, 2003 01:07 AM
