Searching for flywheel
Old Oct 14, 2020 | 05:02 PM
Brendon Griffin's Avatar
Brendon Griffin
Hello, I recently purchased a 1970 F-250 with the 390 FE and a 4 speed. I am needing to replace the flywheel because the teeth have been stripped out. I have called a bunch of part yards and auto parts stores and the only thing I can find are the new high-performance Ford flywheels for $300+. Any recommendations for finding a flywheel?
Old Oct 14, 2020 | 05:14 PM
ford390gashog's Avatar
ford390gashog
Replace the ring gear, nothing wrong with the flywheel unless its cracked.
Old Oct 14, 2020 | 05:16 PM
Brendon Griffin
Never done that before, from what I've researched, I just need a hammer and chisel with a torch or way to heat the gear?
Old Oct 14, 2020 | 05:19 PM
ford390gashog
The best way is to let a machine shop do it. Here its 30.00 and I don't hassle with it. You can do it at home but you need a real torch for this job. The ri g gear is fairly cheap.
Old Oct 14, 2020 | 05:22 PM
Brendon Griffin
Oh, if that's something they can do, I hadn't even thought about having them do it. Should I be planning on getting the flywheel resurfaced at the same time? Should I replace any parts while I'm doing work in that part of the truck (clutch, linkage, etc)?
Old Oct 14, 2020 | 05:34 PM
ford390gashog
Yes have them resurface it at the same time. Replace the z bar bushings and pivot bushing.
Old Oct 14, 2020 | 05:36 PM
Brendon Griffin
Thank you for the help and advice!!
Old Oct 15, 2020 | 04:13 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
180T flywheel ring gear is the same 1965/67 F100/350 352, 1968/76 F100/350 360/390 // 1965/71 352/390 Passenger Cars, should be available from auto parts stores.
Auto parts store machine shops can sweat the old ring gear off, sweat the new ring gear on.
dmock
Sep 19, 2019 08:07 PM
williamwilliam
Nov 12, 2012 03:38 PM
Kalve
May 25, 2010 11:44 AM
Fair 96
Aug 18, 2006 12:01 AM
