428 flywheel
Old Aug 16, 2006 | 08:55 PM
Fair 96's Avatar
Fair 96
428 flywheel
I am looking for a 428 flywheel either good used or a reasonably priced place to buy one. Any help appreciated...
Old Aug 17, 2006 | 11:29 AM
pbear6969's Avatar
pbear6969
Are you wanting a flywheel or a flexplate?
Old Aug 17, 2006 | 12:42 PM
Fair 96's Avatar
Fair 96
I am wanting a flywheel I got a 4 speed car..
Old Aug 17, 2006 | 02:19 PM
bmc69's Avatar
bmc69
I gave up looking for one after about 6 months and just bought a new Centerforce. Of course a good deal showed up on Ebay not two weeks after that..(sigh). It is really hard to find the factory 428 flywheels with the cast-in counterwieght. The Centerfore was simply their 'standard' FE flywheel drilled all to heck to make it 428 balance. I suppose you could just do that with a 360/390 flywheel as well if you have a good balance shop nearby that knows where the imblance is supposed to be clocked.
Old Aug 17, 2006 | 02:38 PM
fordraceboy's Avatar
fordraceboy
If the motor is apart, you'd probably be money ahead to just get the crankshaft zero balanced so it wasn't an issue ever again.. JMO
Old Aug 17, 2006 | 03:39 PM
Fair 96's Avatar
Fair 96
I am buying a new scat 428 crank would I be able to use my 390 flywheel if the crank was zero balanced. Or how would I do this?? Thanks..
Old Aug 17, 2006 | 03:54 PM
bmc69's Avatar
bmc69
And of course I spent all that time looking for a flywheel, bought the expensive Centerforce, and then hauled everything to the balance shop anyway.
Good point.
Old Aug 18, 2006 | 12:01 AM
fordraceboy
if the crankshaft is zero balanced any FE flywheel or flexplate would work, except a 428 one.. LOL
